Tablets & eReaders Logo
A
Anonymous Posted on Apr 04, 2014
How to empty the trash can on iPad
On iPad air how can you empty the trash can?
Michael Lei
Level 3:
Master:
  • Apple Master 498 Answers
  • Posted on May 27, 2019
Michael Lei
Apple Master
Level 3:
Master:
Answers
498
Questions
0
Helped
122097
Points
1736
Not like Android phone, iPad will not produce much trash. But you can empty app trash through below steps. Empty Photos Trash on iPad 2/Air There are a large number of photos on your iPad, you can go through the trash folder called "Recently deleted photos" from Photo app on the iPad. You can imagine how much space has been taken up on your iPad by the deleted photos. Therefore, learning how to empty Photos on iPad is essential to release more space for your iPad. You can follow the simple steps as below.
1. Launch your photos app on iPad.
2. Open the albums list by tapping on Albums menu, then hit on the option "Recently Deleted".
3. You will see the button "Delete All", then tap on this button to make the photos trash empty on your iPad.
Empty Notes Trash on iPad 2/Air 1. Run Notes app on your iPad. If the Notes app does not show up in the screen of Folders, tap on the button Back arrow on the top left corner on the screen till you can see it.
2. Tap on the option "Recently Deleted" and then tap on the option "Edit" on the top right corner.
3. Tap on the button "Delete All" on the right bottom corner, then tap on "Delete All" one more time in the pop-up dialog to get rid of notes from iPad memory.
Empty Mail Trash on iPad 2/Air 1. Open Mail app on your iPad. Choose the email account that you would like to make the mail trash empty.
2. Tap on "Mailboxes" on the top left corner, then tap on the option "Trash > Edit".
3. Tap on the option "Delete All" on the right corner bottom and then confirm the option "Delete All".
Empty Whole Trash on iPad 2/Air through Erasing Device Erasing all content on iPad is a great solution to empty whole iPad trash. The following tutorial will guide you on how to empty trash on iPad completely.
1. Run Setting app on your iPad, this app icon looks like a turning gear.
2. Tap on General on the left column of the screen.
3. Scroll down to the bottom of screen and then tap on Reset.
4. You will see several available options of resetting for your selection. Then choose the option Erase All Content and Settings, which is able to make all the data erased from your iPad including your iTunes account.
5. Then a dialog pops up and requires you to have a confirmation on your selection one more time. This operation will make your iPad recover to factory default. Once you have confirmed your selection, the data erasing process will begin on your iPad. After the erasing process is finished, all data on your iPad will be erased and your iPad will return to factory default, that means all trash on your iPad will be emptied completely.
How to empty the trash can on iPad - empty-mail-trash-on-ipad-3-fcq4m0tsyvw52knfkkvamm2p-1-0.jpg For more details, check: How to Empty Trash on iPad
Hampi Hemp
Level 3:
  • Apple Master 706 Answers
  • Posted on Dec 24, 2014
Hampi Hemp
Apple Master
Level 3:
Answers
706
Questions
0
Helped
238736
Points
6294
- there is NO trash can on any iPad.
however you can empty some hidden cache etc. and free space by making a hard shut-off.
To turn off your iPad, first press and hold the Sleep/Wake button on the top-right corner of your iPad. After a few seconds, the red "slide to power off" slider will appear. Simply swipe it to the right and your iPad will power off.
-wait about 20seconds (until the dim-lighted spinning wheel disappears) and turn it on again
How to empty the trash can on iPad - empty-trash-ipad-ehncqbmo5uzin3tthkqs5khp-2-0.jpg empty-trash-ipad-ehncqbmo5uzin3tthkqs5How to empty the trash can on iPad - empty-trash-ipad-ehncqbmo5uzin3tthkqs5khp-2-9.jpgmages/empty-trash-ipad-ehncqbmo5uzin3tthkqs5khp-2-9.jpg How to turn off your iPad
3 Related Answers
agc93
Alistair Chapman
  • 44 Answers
  • Posted on Feb 28, 2011
SOURCE: how to empty trash in
In general, an iPad doesn't have a trash at all. Since you don't have access to the file system, files cannot be user-modified or deleted, so a trash is not necessary. Further, apps will generaly take care of their own cache and data usage, so user interventions doesn't generally occur. If you are talking about mail, try using the usual delete functions while navigating the Trash folder and you should permanently delete the message.
Hope this helps, Alistair
Anonymous
  • 15 Answers
  • Posted on Mar 06, 2011
SOURCE: How to empty trash on ipad
When you hold down on the app icon and it shakes with a little x in the left corner, that deletes an app. Once an item is deleted that is it. There is no trash can like on a mac.
Anonymous
  • 97 Answers
  • Posted on Mar 13, 2011
SOURCE: How do I empty the trash can on my ipad
Hi! Well, I'm happy to inform you that there is no trash can on the iPad. Apple is trying hard to simplify the usage as much as they can, hence no trash can to be found.
I delete emails but they still remain on the ipad
If you deleted emails they should be in trash. They need to be deleted from trash, too. After emptying the trash they will be gone.
How do I empty trash can?
Hello Again Bertie,
I've got good news for you, iPad's don't have Trash Cans!
I hope this helps,
Niall
2answers
You can find trash files like Android phone, but there still are some apps trash can be empty. Just follow below steps.
How can I Empty my Trash Can on an iOad 2 ?
I did simple web search for Ipad 2 empty trash! I would stick with the advice from Apple! I bet they have a video you can watch! Good Luck!
1helpful
Empting the trash can when I am through putting my old emails in it
Dear Thomas,
There is an easy way to empty the trash folder on your iPad email app. Here is how:
1. Open the "Mail" app on your iPad.
2. Tap on the upper-left icon in the Mail app. It might say, "Mailboxes" or in my case, it says "Gmail".
3. Tap on the email account you are using. Mine says, "Gmail", yours might say, "Yahoo" or whatever program you are using.
img_0355.png 4. Tap on the "Trash" folder for your email account.
img_0356.png 5. Now that you are looking at the items in the trash folder, tap on the "Edit" button located just to the right of the word, "Trash".
img_0357.png 6. Tap on the "Delete All" icon at the bottom of the screen.
img_0358.png 7. A larger "Delete All" button will appear. Tap on that as well.
img_0359.png 8. In a few seconds (or longer if you have lots of messages in the deleted folder) all your messages will be gone and the "Trash" folder will be empty.
2helpful
How to empty trash in apple ipad
14helpful
2answers
4helpful
2answers
1helpful
Can't delete emails from trash
Hello sir !
Empty Trash Can
In 1982, when Apple created the Apple Lisa user interface, they implemented what they called the Trash Can. The trash can is essentially purgatory for files a user no longer wants. Once sent to the trash, the user has the option of restoring the file back to its original place, or annihilating it completely from the computer’s hard drive. Unless there is a backup of a user’s system from before the file was sent to the trash, there is essentially no way of restoring that file once the trash has been emptied.
This metaphor was carried over to Windows 95 in the form of a Recycle Bin. Perched on the desktop of countless millions of averages users was this bin which, when empty, looked empty, and when it contained files, looked full.
There is safety in the Trash Can metaphor. I know that in order to really delete a file from my system, either on Windows or on Mac OS X, I really have to work at it. Yes, there are times when files are accidentally deleted, but for the most part if I realize my mistake before I empty my Trash, I know the file is safe.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
