Irons Logo
A
Anonymous Posted on Apr 04, 2014
How do I turn on? re Hamilton Beach Durathon Iron
Cant the Hamilton beach iron model 14505 reset, it's not heating up and the lights keep going on and off
There is no reset, You will have to replace iron. Based on the price there are repair parts available.
Iron won't heat up
check the thermal fuse stick on the iron plate inside the machine or clean the thermostat under the knob
My hamilton beach iron will not steam
see the diagram and see if there are any part broken, or worn and replace. Tank or ports clogged.and repair
Water leaking out of iron no steam I have a Hamilton Beach Steam Storm Model 14560 Lost manuel
The Use and Care Guide for the Hamilton Beach Iron can be downloaded here:
http://useandcares.hamiltonbeach.com/files/840091300.pdf
If water is leaking out of the iron:
• Do not overfill the water tank.
• If steam ironing, is Adjustable Steam Knob in a steam position that matches Temperature Control Dial steam range? Did the iron have enough time to preheat?
• If dry ironing, make sure the Adjustable Steam Knob is in the DRY IRON position.
2helpful
My iron shuts off when I am continuously ironing.
The flashing is a indication that somthing is failing.. More than likely it is a internal component..
It might be most efficent to get a new one..
Or bring it back if it is under warranty..
Good luck..
Hamilton Beach Ultra Steam Iron Model #15410
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Top Hamilton Beach Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Hamilton Beach Iron Expert? Answer questions, earn points and help others
