I can't make my clock set to 12 hour time. I follow the instructions, but when I press "Set" only "24" flashes. I can't find 12* time
Try:
OPERATION MANUAL - Lexon www.lexon-design.com/media/manuel/LR111.pdf
If this does not work a google search may bring results.
SOURCE: Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
SOURCE: how do you set the clock for 12 hr time, not 24 hour ??
On most clock radios, there is a Time button. Usually, just hold it down while adjusting the Hr. or Min. I have not seen too many clock radios that do not use that kind of setup.
SOURCE: Matsui Radio Alarm CDCR200 set the clock time, lost instructions
Hold CLOCK SET button down, press HOURS and MINUTES until you get the right time, release CLOCK SET button. This radio alarm unhelpful calls the ON/OFF button "STANDBY"! To turn it on, press the STANDBY button so the standby light is on!
SOURCE: I have already described the initial problem with
Do you remember the last thing that happened before your problem started? Is there a model number?
