If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air. If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents. The fresh food control should be at the normal setting of 5.
https://products.geappliances.com/appliance/gea-support-search-content?contentId=20492
There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
two options...one drain hole blocked in freezer,clean with copper wire/bleach to clear gunge.
two outside temp too cold i.e. unit in garage/outhouse( too cold for compressor )
also check seal to doors.air leaks...
Je your defrost thermostat, heaters or timer is not working correctly or at all. The freezer has the coils that freeze the freezer and cools your fresh food area. When your defrost does not work these coils become blocked with ice and will not let air from fans pass through!!! Leaving a moderate temp in fresh food area.
The problem may be low gas or it may be the thermostat is set too low. First, look at the possibility that you may have the food partly blocking an air channel which is where the very cold air is coming from.. Fridge side should read about 40 F after the door is closed for about an hour. If colder, adjust.
