RCA Lyra RD2840 MP3 Player Logo
A
Anonymous Posted on Apr 04, 2014
Update lyra hd system file - RCA Lyra RD2840 MP3 Player
1 Related Answer
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Sep 07, 2008
SOURCE: RCA Lyra RD2780
If the file is missing, it is difficult to recover. Go to RCA's website, and try updating the firmware.
3helpful
Cannot get files onto device from PC
This unit is actually produced by RCA. If you go to their website you can download Firmware, and Software to update the unit. You can also try to do a "reset". There is a very small button on the bottom, if you press this with a pen and hold it for about 3 seconds it may start working again.
2helpful
How to update my lyra2780a
First you need to download the files from here
http://support.rcaaudiovideo.com/downloads.aspx?product=44
you need
RD2780 Lyra™ A/V Jukebox Software Package (Version 1.0.3.5)
and
RD2780 Lyra™ A/V Upgrade Utility
download both files. the format the lyra from windows explorer (fat32).
the install the a/v jukebox. it will put an icon in the system tray. right clic it and select "update system files" (or something like that). when it´s done, disconnect the lyra from the PC and reboot the lyra. It will update automatically.
then download the second file to update firmware. that should work.
RCA Lyra RD2780
1helpful
Thomson lyra
I don't know exactly which model of the Thomson Lyra you have, but you can visit the Support page on their website, find your particular player model, and download software updates that might help solve this problem.
2answers
File system corrupt
1helpful
Thomson PDP 2860 20 GB MP3-MP4 player
I formated my lyra pdp2860 and it lost the file system so i need to download the right free file system.
Thomson Lyra Jukebox pdp2860 av system files problem
go to this page, http://rcaaudiovideo.com/en-US/RD2780_Upgrade and follow the instructions, i had this same problem, and i fixed mine
6helpful
7answers
My rca lyra rd1080b
this is the best solution you have update your lyra rd 1080/rd 1090 for download the updating click her http://download.rca.com/download/RD1080_90FWUpgrade_v4.26.exe and after instaling this update follwo instructions provided below ? To update your Lyra RD1080/RD1090, make sure you have it connected to the computer via the included USB cable. You will need to make sure that no external memory has been inserted and the Lyra RD1080/RD1090 display reads: "USB Connected Int. Mem". (If it does not, please refer to the users guide for the section on how to switch between internal and external memory.) ? Once connected, locate and run the Lyra Systems File Update Utility if it didn't open automatically. Installshield Wizard will have automatically created this icon on your desktop as well as under "Programs", "Lyra Personal Audio Player", "RD1080/RD1090" in your START menu. ? Click the "Refresh" button until the RD1080/RD1090 player shows up under device. ? Once displayed, highlight the drive letter by clicking on it, and click the "Update SYstem Files" button. ? When successfully completed, you will see the message, "The Lyra Personal Audio Player Device system files were successfully updated." ? Click the "OK" button, and then "Done". This will close the Lyra Systems File Update Utility. ? Disconnect the Lyra RD1080/RD1090 from the USB cable, turn the unit off and back on.
2answers
Error message turning on
Is it possible you deleted system files along with other files by mistake? It's a very common problem, and it would be good to know what causes this since some people say its because the Lyra allows you to delete system files which screws the device. I heard of someone that called Thomson helpline with this problem and got his replaced, so it wouldn't hurt to try. RCA has this page on the problem: http://www.rcaaudiovideo.com/Cultures/en-US/RLDetail.html?ArticleNum=112&PC= It might help... And there's this program that is said to help with the formatting, get it here along with some instructions: http://www.techolio.com/rd2780_upgrade/ Good luck!
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
