Question about Brand Remote Start/keyless/car Alarm Very Sleek
Where is the bmw 94 32i central lock up and down wire to connect
I have a 1989 bmw 320i im replacing the boot but
Hi the wires in the boot are either from the number plate light or central locking if you have that fitted to your car.
Oct 17, 2014 | BMW 320i Cars & Trucks
Central locking stuck on
You most likely have a faulty door latch which contains the central locking actuator, or a broken or shorted wire in the harness on the tail gate, two common problems own this model
Feb 27, 2013 | 1999 BMW 318 ti
I have a 02 bmw 530 i. The locking botton on the console in the middle of the front seats stopped working. Around the same time the central locking system stopped working. I had to unlock door with ke
Check fuses first, then check the wiring connections to the buttons. Possible the plugs are corroded and just need to be unplugged, cleaned, and plugged back in.
Oct 27, 2017 | BMW X5 Series Cars & Trucks
Disconnected battery to reset computer when central locking failed after a blown fuse and as a result bluetooth is now not connecting, it is a 2005 320i and the little telephone icon is not appearing above...
i recently replaced the battery in my 2006 X5 diesel, now the central locking is not working, I am in a remote location and not able to attend a BMW dealer, is there anyway I can resent the central locking. Cheers allen
Apr 22, 2011 | 2005 BMW X5
Central locking does not work on my BMW 320D SE model
hi
there is a motor placed inside the doors for the operation of the central lockin system. when you open the door by key this motos is activated and all door locks are released. your problem may because of this motor is failed.
cause of the failure
1.the wire going to the motor may be chopped off.
2.the junction box connecting the wires may be damaged.
3.fuse may be blown out.
4.motor itsef damaged.
so please check weather power is coming to the motor using multi meter. if the power is not coming to it then the problem is with the wires. if the power is coming to it then problem is with the motor.
i suggest you to take to BMW because you need to remove the door pannel its better if they do it.
please vote me if my answer was useful to you.
Jul 12, 2010 | 2004 BMW 3 Series
2001 330i BMW hazard lights & central locking in car won't work
I'm having the same problem have you fixed yours?
Jul 11, 2010 | 2001 BMW 330
I have a 1997 bmw 318i. the central locking system keeps blowing the fuse. i know there is a short somewhere,but where
I will suggest to check the wire harness from truck. try to take off the rubber grommet close to trunk hinges. then inspect if there is dammage wire but if you can;t find any fault with it, i suggest to disconnect one by one the connector from each door and and obseve the fuse and if the fault still existing check the central locking module for possible water ingress resulting to blown your fuse
Jan 24, 2010 | 1997 BMW 3 Series
My bmw will not start when the central locking fails
There is a computer under the glove compartment that controls the locking system in your car that also works with the alarm system in your car and if that computer is not working properly that is the reason why. If that computer registers that the car was not open properly that it will deactivate the starter
Mar 04, 2009 | 1996 BMW 318
Brand Remote Start/keyless/car Alarm Very Sleek Logo
Top Spy Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Norman Al-Anbar
Kardoc
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
