SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
SOURCE: Maytag dryer stopped working (model LDE9334ACE -
Check your timer switch, that would cause you light not to work.
Also check the bulb, it may be burned out.
I hope this helps
SOURCE: my house circuit breaker kept tripping and
sounds like your heating element has opened up it was probably partially shorted to the case and this was causing your breaker arcing condition previously
SOURCE: Circuit breaker trips after 10 minutes
could be a weak breaker,or poor high resistance connection from panel to dryer plug, then have someone check the current draw on the dryer while operating and see if it's within specs of the machine tag, if it's higher than that you may have a defective motor or heating element to case causing a higher than normal current draw
SOURCE: Our Maytag Intellidry PYE4558AYW dryer will not turn on
Check the door interlock switch. If it is defective, the machine will not start. If no help, then there may be trouble in the control panel.
