Newly acquired e10 machine, developed a leak, quite badly from the bottom rear area. A few days later it stopped working and shows a general fault code.
SOURCE: when i turn on to make sxpresso the machine works
its not coming out because heating eleament is not working properly. replace
SOURCE: jura fault 1
According to the Jura Coffee Machine Error List, you machine needs a service, have you made 5,000 cups since your last service?
SOURCE: Water leaking jura s9
I have solved a leak doing as suggested by hhmartins. There was noticeable white scale around a couple of connections and these were cleaned up.
Could there be a blockage? The pressure relief valve (small round thing) was easily removed and cleaned.
(I have posted my own puzzle about whether I've reassembled the brewing unit properly)
SOURCE: eam3500 delonghi coffe machine
From page 21 of the owner's manual: Message: general alarm. Meaning: The inside of the appliance is very dirty. What to do: Clean the inside of the appliance thoroughly, as described in section 15. If the message is still displayed after cleaning, contact a service center.
Hope that all your machine needs is a thorough cleaning; it's not that difficult.
SOURCE: Jura Capresso F7
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
