Office was wired that way i have one tried several ways to use it without the lifter did't work had to buy a lifter the next problem is the phone not all will work Cisco uniden will work good
You can use a standard PC or cell phone headsets with Cisco phones. With help of our adapters, you can convert computer headset, smartphone headset or cordless phone hands-free into Cisco compatible headset. Cisco IP Phones
I know it may be late (definitely late), but have you defined in the CallManager, that your phone has a "side card"? If CallManager does not know that it has to push an additional firmware to a particular phone, it will not work.
You can use a Plantronics S11 headset with a Cisco phone, however it is
not the best compatible solution. To use an S11 with a Cisco phone, you
have to make sure that you are plugging it into the handset receiver
jack and not the headset jack. You will need to lift the handset
receiver, set it off to the side, and then hang it up after each call.
If you want a more compatible solution that you can plug into the actual
headset jack and just press the headset button on the telephone to
answer and hang up, then you would need one of the Plantronics "H-series headsets" with the Plantronics Cisco direct connect cable ( model 26716-01 ).
James, plug the phone cord that comes out of the back of the CS55 base into the handset port of the Cisco phone, not the headset port. Then plug the coily cord from the cisco receiver into the front of the CS55. Don't use the "Headset" button on your Cisco phone, just lift the receiver off.
