All functions work on this reciever when I use the remote control. Nothing works when I try to use the control buttons onthe reciver itself. The red standby light is on, but unit won't power up with the button, only with the remote
SOURCE: KLH R5100
in stero mold only 4 speeker will work ftr ftl center sub u need a sound sliter cornet it to the tow frount that what i did
SOURCE: connect R5100 to DVR/Monitor
use component audio to the HDTV and optical audio to your KLH reciever. The component and optical are always active at the same time. I work for TWC if you have more questions.
SOURCE: klh r5100
Depending on the watts on your stereo would tell you the most, for example say its 300 watts u buy a 150 watt speaker it would blow the speaker, if you buy a 500 watt speaker your risking frying the stereo, it be best too even it out as best you can, i know that this has nothing to do with what ur asking but it would help you to save more money on buying a new speakers or receiver, now to the answer to you question, i would recommend a 12inch speaker, it would give you good sound quality
SOURCE: KLH R5100 is not turning on
The light is supposed to work in reverse to the system; i.e. light off= system on; light on= system off...
