SOURCE: dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
SOURCE: Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
SOURCE: Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
SOURCE: Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
SOURCE: My Dacor double wall oven was accidentally set to
all looked after - thanks!
Turned off the electrical breaker and the oven reset itself.
good as new!
