Refrigerators Logo
C
Cathy Drewry Posted on Apr 04, 2014
Stopped cooling Not cooling at all. Freezer or Ref. Model PRCS25TDAE Fan is running but I don't hear compresser
abhishek sikder
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Apr 18, 2014
abhishek sikder
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
4121
Points
26
Go to your cooling control pannel ,,,, increase its number, set high your freezer temp, if you dont get any benifit, call to a service man . your compressor may be stopped working
5 Related Answers
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Jun 19, 2009
SOURCE: Refrigerator is not cooling
I need you to check a few things with the refrigerator unplugged. When ready, Let me know.
Anonymous
  • Posted on Jul 25, 2009
SOURCE: Freezer works ref does not
freezer working good refrigerator isnt
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Aug 17, 2009
SOURCE: refrigerator not cooling
You model if the ARB1950C has a defrost timer inside the fresh food compartment and behind the temperature control panel. Need to see if you can manualy turn the timer clockwise until the compressor stops. During that time of 25 minutes the freezer should be in defrost. I believe your timer needs replaced based on how you explained what is happening. The part number for your timer is 67001036 and can be found at the links below. If it stays longer that 25 minutes then it's sticking in the defrost section of the defrost timer and will need to be replaced. If your refrigerator does not restart after about 25 minutes then slowly turn the timer through the opening in the plastic cover. There may be a plug covering the hole to make the hole not so visible. If you should have problems fell free to let me know, Thanks Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Anonymous
  • 1606 Answers
  • Posted on Oct 02, 2009
SOURCE: Stopped cooling but i can hear running
The overload/relay is probably bad .This is the part plugged onto the compressor , with 2 or 3 wires plugged onto it . You can easily replace this part . Be sure to have your model number when ordering .
Anonymous
  • Posted on Feb 12, 2010
SOURCE: psc25mstass freezer not cooling
I had a problem where the temperatures in both refrig and freezer wouls fluctuate. Would not geep ice cream frrozen in top of freezer but temp gauge would read 0. Even stranger would have stalagtites forming from the top shelves in the freeser (big ones). Still under extended warantee so tech replaced the mother board and iit is functioning well now.
Maytag fridge not cooling
If the ref or freezer is too warm and you turn the dial to make it colder the compressor should come on. If the ref or freezer is not cold like you say the compressor should be on all the time. You should hear it, but you can definitely feel it and it should be very warm after a short while.
If the compressor does not get warm unplug the ref with the compressor running and plug it back in immediately. A good compressor should not start up right away.
If it is running and not getting warm and does start right up after unplugging it and plugging it back in it is inefficient and not compressing the freon gas enough and therefore not cooling enough.
The fan in the freezer should be running as should the fan under the refrigerator.
The condenser should be warm and the fan should be blowing[drawing] air across it when the compressor is on.
You don\'t repair compressors and to recharge them correctly is expensive.
I have a Samsung refrigerator model number rs257barb. After a power outage my fridge stopped cooling to cool temperatures. It would only cool to lowest 75. The weird thing is the freezer side was still...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
My Kitchenaid Refrigerator (Model# KBFS25EVBL) seems to have stopped cooling correctly. The outlet is working and the fridge is still getting power, I can feel/hear the fan at the rear of the freezer...
NOTE: This
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
Check cold control (thats where you turn it colder)
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
I have a GE Profile side-side refrigerator - model PSS26SGPASS. The refrigerator and freezer stopped cooling completely all of a sudden. All controls on the display are working but it does not cool even...
NOTE: This
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
MORE TIPS AND TRICKS:
Leo Ponder
imufo2
Freezer works fine but fridge side stays at about 45 degrees
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
1helpful
2answers
Refrigerator/freezer not staying cool
If there is no frost on the freezer side it may be low on coolant.
Freezer is fine. Fridgerator portion does not cool .
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
My Whirlpool ARC7472 fridge freezer has stopped cooling both feezer and fridge. Removal of the cover in the freezer shows no ice build up, the fan runs, but no cooling effect in the chiller pipework to the...
it is low on refrigerant and has a sealed system leak without the proper leak detection equiptment and charging tools best left to the local ref tech
1helpful
GE model GTST2BPLWW
they all have fans the freezer does all the cooling for the whole unit there is nothing in the bottom unit that cools the freezer fan blowes air from the freezer down to the bottom and draws air to the top if you dont hear the freezer fan running and there would be no doubt in your mind if it was then pull the fan cover and see why and let my know hold my rating till we are done please
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
