I need to know where the fuse is located or which plug to replace, , i cant tell where the wires are leading to exactly after going up though the hole on the bottom, the circiut board has wires coming off that go to plugs but none are directly behind the button switch for the lights, i added a ton of info in my summary above, everything on the microwave works perfect as before i shorted the lights, the fan, clock, timer, it heats, inside light, the surface/hood lights are the only thing i cant get to turn on, the display still reads on/off when i push the button
SOURCE: Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid. This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller. This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on. If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
SOURCE: Tried to replace the surface light bulbs on my
Yes you should replace the fuse which in the control department. You must remove the cover which is one unit the top, left and right panel. Also sometime the bulb holder wires might have be loose or burned out and been disconnect so this have create an open circuit. So you can have a visual check of these wires but since you have the oven panel removed have a check of loose or overheated wires. Take care to remove electric plug and avoid come in contact with the magnetron capacitor since this can evacuate instant high voltage and might burn your hands, and this hurts very bad for more than a week. We have a link with the parts layout of your microwave which can help you.
Most major manufacturers supply manuals
online so if you were to log on to the manufacturer's web site, you
may be pleasantly surprised as usually, if available, one is able to
download, by model number, Customer
Instruction Manuals, Dealer
Network for spare part supplies as
required.
The information is normally free of
charge.
I hope this helps.
