While typing, my cursor will jump to the location of the mouse on my window. This could be in another application or within the same application. This occurs using the laptop alone, and while it is in a docking station. The touch pad is not available while in the dock. This has caused significant re-writes and is more than just an irritant.
Try these steps might your computer is infected.
Step Followed:-
1. Click on start and type Run.
2. In Run box type Temp.
3. Select all and delete all files.
4. Follow 1st step and type %temp% and then follow 3rd step.
5. Follow 1st step and type prefetch and then follow 3rd step.
6. Follow 1st step and type appwiz.cpl (add and remove programs)
7. Remove unwanted software and all antivirus .
8. Restart the computer.
9. Download Malwarebytes from "http://www.filehippo.com/download_malwarebytes_anti_malware/download/d7670bee6c8cd1bb9341d9a1ffbe832f/ "
10.Scan your computer and remove the infection.
Thanks
SOURCE: Mouse Cursor Jumping while typing causing major typing errors
Reinstall the Mouse Drive rplease and it should work.
Please write abck if you still face problems.
SOURCE: when typing, my cursor will randomly jump to some
Hi rbdav1,
Based on your situation. I suggest trying the following steps:
1. Download touchpad driver from here:
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=600154
2. go to Touchpad section and make sure you select the Windows XP, Vista or Windows 7 version of the drivers that matches your Windows operating system.
3. After downloading the touchpad driver driver install it and then restart your computer.
4. Log back in to your computer then go to control panel --> open mouse properties then look for Alps pointing device tab.
5. Under Alps tab uncheck tap off when typing.
Hope it helps.
Thanks for using FixYa
Best regards,
Reyjoshua07
TouchPad can not be the issue while it is in a docking station, the lid is closed and I only use a wired mouse.The wired mouse can't be the issue since it is not used when un-docked.
Raynoldo - I like the idea of turning off the touch-pad while typing. I will ask our "IT" department to update the touch-pad driver. But since the touch-pad is not available when docked, do you think this would help the over-all issue?
