SOURCE: i tried adding 2 gb od ram and the screen will not
Make sure it will run clean without the addition of the memory,
They have to be install in pair, not a 2 gig alone (as per the manufacturer) and when installing the pairs they have to be in the same color slot ( they are not side by side).
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
