Home Security Logo
A
Anonymous Posted on Apr 04, 2014
Dcs 5501 trouble light
Same time five day in a row , at the receiver. won't clear at key pad!
schmidtsd
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Apr 10, 2014
schmidtsd
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
Helped
7221
Points
22
When checking troubles on DSC, *2 brings up the trouble codes and trouble light will flash after pressing *2
1=Service Required (press 1 to get sub codes)
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
5=Module Supervision
6=RF Jam Detected
7=PC5204 Low Battery
8=PC5204 AC Failure
2=Loss of AC Power
3=Telephone Line Fault
4=Failure to communicate
5=Sensor (or Zone) Fault --- Press 5 to identify zone/sensor
6=Sensor (or Zone) Tamper --- Press 6 to identify zone/sensor
7=Sensor (or Zone) Low Battery --- Press 7 to identify zone/sensor
8=Loss of Time & Date
1helpful
97 Chrysler.cirrus starts runs good,when you shut it off it won restart unless it sets for about an hour. Head lights,over head light, Windows ,dash light all work ,but it won't crank over.
Starter motors and solenoids often sieze when hot towards the end of their service life. You may need to replace the starter. How many times will it start in a row Without running it long enough to heat up. If it will start four or five times cold then fail after warming up and the alternator is charging the battery at 13.5- 15 volts you got a bad starter.
tip
How To Check & Reset Your 2002-2006 Nissan Altima Service Engine Soon (SES)...
The following directions will help you decode your 2002-2006 Nissan Altima's Service Engine Soon (SES) light and reset it.<br /> <br /> <span style="font-weight: bold;">Obtain The Trouble Code</span><br /> <ol> <li>Turn the ignition key to the ON position and wait three seconds.</li> <li>Put the accelerator pedal to the floor and release it five times in less than five seconds.</li> <li>Wait exactly seven seconds. Put the accelerator pedal to the floor for ten seconds until the SES light flashes.</li> <li>Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.<br /></li></ol> <ul> <li>Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates a zero.) </li> <li> The next three digits blink faster (0.3 second) and have a 1 second pause between digits.</li> <li>The ECM code repeats until you turn the ignition key to the OFF position.</li> <li>You can look up the trouble codes in the Service Manual.</li> <li>If you get four blinks of ten, or 0000, the ECM indicates no malfunction.<br /></li></ul> <br style="font-weight: bold;" /><span style="font-weight: bold;">Clear The Trouble Code</span><br /> <ol> <li> Clear the code and the SES light by holding the accelerator pedal down to the floor for 10 seconds or more while the SES light is blinking.</li> <li>When the pedal is released, the ECM will erase the trouble code(s).</li></ol>
on Feb 15, 2011 • 2002 Nissan Altima
Exchange oil lighting
  • There are a couple different Grand Am's that each reset their own way.
  • I am pretty sure yours resets by ---
  1. Get in the car and put the key into the ignition.
  2. Turn the key on (no start).
  3. Wait five seconds.
  4. Now press the gas pedal to the floor all the way three times in a row.
  5. Wait five seconds and the light will disappear.
  • The other way for some of the Grand Ams are ---
  1. Get into the car and open the fuse panel access panel.
  2. Find the red "reset" button.
  3. Put the key in the ignition to on (no start).
  4. Wait five seconds.
  5. Now press the red "reset" light for ten seconds and the light will blink than go off.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
I have a flashing red light on the top right of my Samsung Falcon 18D phone. There is no voice mail. How do I cancel/clear the flashing light?
Hi, what has happened is someone has sent you a message internally, the only way to clear this on the prostar DCS is to set one of your programmable softkeys to be a MSG key, then follow the prompts on the screen, you can then put the key back to what it was originally. I have put a video on to help you with the progamming of your keys on the prostar DCS, of which there are lots more on YouTube searching abbeytel. or please visit www.abbeytelecom.com for more tips and help. I hope that I have helped you.
1helpful
2answers
What button sequence to I press on the vic to get the cpu codes for the check engine light?
Reading & Clearing Codes READING CODES (EXCEPT CADILLAC) Fig. 4: Example of a code 12 displayed on the check engine lamp 79222g25.gif
Since the inception of electronic engine management systems on General Motors vehicles, there has been a variety of connectors provided to the technician for retrieving Diagnostic Trouble Codes (DTC)s. Additionally, there have been a number of different names given to these connectors over the years; Assembly Line Communication Link (ALCL), Assembly Line Diagnostic Link (ALDL), Data Link Connector (DLC). Actually when the system was initially introduced to the 49 states in 1979, early 1980, there was no connector used at all. On these early vehicles there was a green spade terminal taped to the ECM harness and connected to the diagnostic enable line at the computer. When this terminal was grounded with the key ON, the system would flash any stored diagnostic trouble codes. The introduction of the ALOL was found to be a much more convenient way of retrieving fault codes. This connector was located underneath the instrument panel on most GM vehicles, however on some models it will not be found there. On early Corvettes the ALOL is located underneath the ashtray, it can be found in the glove compartment of some early FWD Oldsmobiles, and between the seats in the Pontiac Fiero. The connector was first introduced as a square connector with four terminals, then progressed to a flat five terminal connector, and finally to what is still used in 1993, a 12 terminal double row connector. To access stored Diagnostic Trouble Codes (DTC) from the square connector, turn the ignition ON and identify the diagnostic enable terminal (usually a white wire with a black tracer) and ground it. The flat five terminal connector is identified from left to right as A, B, C, D, and E. There is a space between terminal D and E which permits a spade to be inserted for the purposes of diagnostics when the ignition key is ON. On this connector terminal D is the diagnostic enable line, and E is a ground. The 12 terminal double row connector has been continually expanded through the years as vehicles acquired more on-board electronic systems such as Anti-lock Brakes. Despite this the terminals used for engine code retrieval have remained the same. The 12 terminal connector is identified from right-to-left on the top row A-F, and on the bottom row from left-to-right, G-L. To access engine codes turn the ignition ON and insert a jumper between terminals A and B. Terminal A is a ground, and terminal B is the diagnostic request line. Stored trouble codes can be read through the flashing of the Check Engine Light or on later vehicles the Service Engine Soon lamp. Trouble codes are identified by the timed flash of the indicator light. When diagnostics are first entered the light will flash once, pause; then two quick flashes. This reads as DTC 12 which indicates that the diagnostic system is working. This code will flash indefinitely if there are no stored trouble codes. If codes are stored in memory, Code 12 will flash three times before the next code appears. Codes are displayed in the next highest numerical sequence. For example, Code 13 would be displayed next if it was stored in memory and would read as follow: flash, pause, flash, flash, flash, long pause, repeat twice. This sequence will continue until all codes have been displayed, and then start all over again with Code 12. CLEARING CODES (EXCEPT CADILLAC) Except Riviera, Toronado and Trofeo: To clear any Diagnostic Trouble Codes (DTC's) from the PCM memory, either to determine if the malfunction will occur again or because repair has been completed, power feed must be disconnected for at least 30 seconds. Depending on how the vehicle is equipped, the system power feed can be disconnected at the positive battery terminal pigtail, the inline fuse holder that originates at the positive connection at the battery, or the ECM/PCM fuse in the fuse block. The negative battery terminal may be disconnected but other on-board memory data such as preset radio tuning will also be lost. To prevent system damage, the ignition switch must be in the OFF position when disconnecting or reconnecting power. When using a Diagnostic Computer such as Tech 1, or equivalent scan tool to read the diagnostic trouble codes, clearing the codes is done in the same manner. On some systems, OTC's may be cleared through the Tech 1, or equivalent scan tool. On Riviera, Toronado and Trofeo, clearing codes is part of the dashboard display menu or diagnostic routine. Because of the amount of electronic equipment on these vehicles, clearing codes by disconnecting the battery is not recommended. Riviera, Toronado and Trofeo (Non-CRT/DID Vehicles) — Using The On-Board Diagnostic Display System: First turn the ignition to theON position. On Riviera depress the OFF and TEMP buttons on the ECCP at the same time and hold until all display segments light. This is known as the Segment Check. On Toronado and Trofeo follow the same procedure, however, depress the OFF and WARMER buttons on the ECOP instead. After diagnostics is entered, any OTC's stored in computer memory will be displayed. Codes may be stored for the PCM, BCM, PC or SIR systems. Following the display of OTC's, the first available system for testing will be displayed. For example, 'EC?' would be displayed on Riviera for EOM testing, while on Toronado and Trofeo the message 'ECM?' will appear. The message is more clear on these vehicles due to increased character space in the IPO display area.
  1. Depress the 'FAN UP' button on the ECCP until the message 'DATA EC?' appears on the display for Riviera, or 'ECM DATA?' is displayed on Toronado and Trofeo.
  2. Depress the 'FAN DOWN' button on the ECCP until the message 'CLR E CODE' appears on the display for Riviera, or 'ECM CLEAR CODES?' is displayed on Toronado and Trofeo.
  3. Depressing the 'FAN UP' button on the ECCP will result in the message 'E CODE CLR' or 'E NOT CLR' on Riviera, 'EOM CODES CLEAR' or 'ECM CODES NOT CLEAR' on Toronado and Trofeo. This message will appear for 3 seconds. After 3 seconds the display will automatically return to the next available test type for the selected system. It is a good idea to either cycle the ignition once or test drive the vehicle to ensure the code(s) do not reset. Toronado and Trofeo (CRT/DID Equipped) — Using The On-Board Diagnostic Display System: First turn the ignition switch to theON position. Depress the 'OFF' hard key and 'WARM' soft key on the CRT/DID at the same time and hold until all display segments light. This is the 'Segment Check.' During diagnostic operation, all information will be displayed on the Driver Information Center (DIC) located in the Instrument Panel Cluster (IPC). Because of the limited space available single letter identifiers are often used for each of the major computer systems. These are: E for ECM, B for 6CM, I for IPC and R for SIR. After diagnostics is entered, any OTC's stored in computer memory will be displayed. Codes may be stored for the PCM, BCM, PC or SIR systems. Following the display of OTC's, the first available system for testing will be displayed. This will be displayed as 'ECM?'.
  4. Depress the 'YES' soft key until the display reads 'ECM DATA?'.
  5. Depress the 'NO' soft key until the display reads 'ECM CLEAR CODES?'.
  6. Depressing the 'YES' soft key will result in either the message 'ECM CODES CLEAR' or 'ECM CODES NOT CLEAR' being displayed, indicating whether or not the codes were successfully cleared. This message will appear for 3 seconds. After 3 seconds the display will automatically return to the next available test type for the selected system. It is a good idea to either cycle the ignition once or test drive the vehicle to ensure the code(s) do not reset.
1helpful
Every once in a while my key pad first letter row Q thru P and second letter row keys a thru L will not operate. When the letter q is pushed qa will come up on the screen and when you push the a key qa...
Keyboard errors are Locale setting errors.
check your regional languages in control panel,
are set to english at the top, and save it.
Should be good if hardware ok
Regards
Richard.
DCS over F7 error beeping
KEYPAD BUTTONS ARE REMAINING CLOSED FOR MORE THAN 32 SECONDS. REPLACE KEY PAD,DUE TO STERCHED PANEL MEMBRANE
1helpful
Nothin works on my key pad
Here are lock / unlock schemes for three recent Sanyo models:
- Press and hold Stop/Cancel for 3 seconds
- Press and hold Stop/Reset for 3 seconds or so
- Press Stop/Clear five times
Hopefully one of those will work.
If none of these work for you, contact Sanyo Service Customer Service.
We're happy to help and we appreciate your thoughtful rating of our answer.
16helpful
12answers
Set time and date
hit the feature button (gray, looks like a globe on it) under the display, under the 3 gray buttons in a row.
then **8463
password is 23646
follow prompts :)
hit the hang up (phone with arrow underneath) when fone.
Top DSC Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a DSC Home Security Expert? Answer questions, earn points and help others
