My washing machine doesn't work...the start/pause light keeps on blinking. Please help!!
Accoriding to the user manual the probable failure might be that the door is not shut properly, however in my case it is and we even hear the click sound when it closes. Is there any other solution for this problem?
Hello. Make sure the "child lock" hasn't been activated--it will lock the control panel functions. To de-activate it if on, press and hold the "prewash" button for at least 3 seconds. You will see the "child lock" become unlit in the display and the machine will work normally. Also, make sure the "delay wash" hasn't been activated--get your user manual and read the section on "delay wash"--you aren't the first--and definitely won't be the last user who has inadvertently set the delay wash feature! Let me know what you find. Thanks!
There is a button to the left of your selector dial. I believe it's the PAUSE/CANCEL button. Press this button and this should reset your machine. You should have this info in your manual under troubleshooting. Please let me know how you make out. GOOD LUCK FRIEND.
you might be putting the detergent in the wrong part of the dispenser,or you might have the hose on the wrong way,or the water valve has failed. Read up on your user manual to see what happens on this part of the cycle,does the w/m empty ,then try and bring in more water?? The main give away to this fault is,detergent still in the dispenser.Check all your filters on your inlet hose and water valves. You have to ask yourself what has changed,cheers.
Hi Press and HOLD the Start/Pause and Cancel buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance. Daniel
Hi, If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy. If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv. You will see 3 seconds long pause between blinks so count pause to pause.
try unpluggin unit for 10 or 15 minutes sometimes a computer will lock up. If this doesnt fix it there is a tech sheet located behind the lower removable panel (3 screws down on your knees and look up a little between the door panel and lower panel. Tech sheet can help you with minor problems but be careful parts are expensive and non-refunadable (electrical parts). always disconnect power before working on unit
