Question about Leisure GRB6CVR Electric Cooker with Ceramic Hob, Regency Red
How do I remove the glass on the main oven?
The manual says use the spade, but I dont want to force it and break the glass
  • Gillian Murphy
    Gillian Murphy Nov 14, 2015
    Did you find out how to do it. Im stuck too. Manual has wrong door.
    Top Expert:
  • Leisure Master
  • 62,972 Answers
Most have screws around the edge that need to be removed . then the inner and outer shell can be separated .
Posted on Nov 21, 2015
2 Suggested Answers
SOURCE:
rgall3285
  • 62972 Answers
SOURCE: Oven door on my Leisure Cookmaster101 wont close tight enough , how do I correct this problem?
perhaps looking here for a manual will help Brochures and Manuals for Leisure Freestanding and Range Cookers
Posted on Feb 06, 2015
Testimonial: "Ray , put in model Leisure cookmaster 101 not recognised."
Replace light inside oven
Switch oven off and switch main oven switch on wall off if no wall switch, switch off at main switch board.
Open door and check glass cover if it screws off or has retaining screws. be careful as it could be hard to loosen, once loose unscrew lamp anticlockwise slowly as lamp my break off base if tight move side to side very little and unscrew. get replacement and replace opp to removal. Switch on main switch and test.
Oct 17, 2014 | Ovens
I need to remove glass light cover on stoves oven model 444445115 without breaking it to change the bulb
hi hold it with a damp cloth and turn ..if it dont unscrew u need to change the unit as a whole :( they end up breaking .
Feb 27, 2011 | Ovens
We have a multifunction freestyle over 698 and want to change the light inside the oven. how do we do this
The glass cover over the bulb should screw off, remove the bulb and replace it with a new one of the correct type. Clean and replace the glass cover. Be careful not to use force which could break the glass and cause an injury. Make sure that the stove main switch is off. (The lamp cover may have a screw type or have a bayonet fitting).
Jan 17, 2011 | Ovens
How to change the oven light bulb in a candy f245. Glass cover on inside doesn't seem to undo - moves a bit each way. No apparent access from outside.
The glass cover does come off. Use some latex gloves or non skid material and grasp the lens firmly and turn counter clockwise.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 15, 2009 | KitchenAid KEHC309 Electric Double Oven
Trying to unscrew bulb cover in a neff oven
no WD-40, turn of the power, break the bulb and remove the base with pliers. More than likely there is dielectric corrosion between the base and the socket and this makes removal next to impossible
Jun 13, 2009 | Neff U1721 Double circotherm Electric Oven
Trying to replace main oven bulb: cover jammed
Try heating it up with a hair dryer or similar if that does not work then you will probably have to break the glass cover.
Nov 17, 2008 | Neff U1461 Double circotherm plus Electric...
Wiring up the heater elements on the electric door mirrors.
I have a Mazda 6 Estate - I've just had the glass out of my mirror this evening, because my mirror heater is not working - there was a bunch of wires into the mirror unit - two of which went to spade connections on the back of the mirror.
The glass itself is on a plastic mount. The mount and the glass should just lever/pull out - that's what I did with mine - I was worried it was going to break though, it took substantial force! Once out I could see a plastic rectangle with rounded corners that it had been clipped onto. It clipped back into place with out any difficulty (on mine there is a wire guide behind the glass - just make sure that you haven't bent it upon removal - I had, but the pliers straightened it again).
Oct 12, 2008 | 2002 Mazda Miata
NEFF Oven
brute force i'm afraid. try using a pair of mole grips. its not the end of the world if you break the glass
Oct 02, 2008 | Ovens
How to change oven light
unscrews anti clock wise dont lever glass (like i did) with a knife it breaks. the metal bit that the glass screws into will spin thats why it wont undo.
Oct 10, 2007 | Ovens
Leisure GRB6CVR Electric Cooker with Ceramic Hob, Regency Red Logo
437 people viewed this question
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
Chuck Graybill
ray gallant
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
