Is TP-LINK TD-W8901G Router using WPS or aoss
SOURCE: My tp-link TD-W8950ND 150Mbps Wireless Lite
this is because your modem is out dated your better off getting a new one
SOURCE: i am using tp link
If you are paying for a downlink speed of 384 Kbps you should be getting at lease around 300. First bypass your router - connect your cable/DSL ethernet line directly from the modem to your PC. Go to http://www.auditmypc.com/internet-speed-test.asp run the speed test and see what your download speed is.
If it's less than 300 call your service provider & ask them to check out your line. If they say that you are getting 300 Kbps or more, you have a problem with the ethernet card in your PC. Replace it.
Of course, if your speed is OK when you bypass the router, you have a router problem. Contact the manufacturer or replace it.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Hi ,This is Clare Su from TP-LINK support technical force.To you issue,I have the following recommendations:1. try to use only one line to connect to the internet,and see if you can watch the video on youtube2.if you can see the video with one line connected to the internet.Then,you can get another internet line with the router.And you can try to set the rule to the website: youtube, let the flow from youtube come in and out just from one wan port.if you can't solve the issue with my recommendation,you can email me. I will help youas soon as possible.My email is:clare.su from tp-link.com
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
SOURCE: I just brought a Tp-link TD-w896ON but the internet speed 1.67 mbps ??
The line speed is controlled by your internet service provider, not by your router. If you have something like AT&T as your internet service provider, then they sell 3 or 4 different line speeds or packages. The cheapest will get you the slowest line speed. So if you have a 300mbps router but you purchased AT&T's cheapest line speed it will never allow you to do downloads, uploads or streams at 300mbps. You gotta Pay to Play. :)
