Tried to start, waited about a minute then tried again, heard a pop come from the front end and still wouldn't start. waited a couple more minutes tried to start and started right up. any idea's?
SOURCE: 1986 Yamaha Radian stops running after 20 minutes
Sounds to me like it could be a few things... pretty interesting that it runs and shuts down...sits for a little while then fires back up. Could be something as simple as a bad ground.. maybe it needs cleaned.. if the ground is making very little contact.. the bike would run bad, and because its direct current it has to flow. The metal in the motor frame etc will hold so much DC current.. but *** soon as it load up the bike would stop sparking. Let it sit for a while, DC trickles into the battery through the slight contact, bike fires back up. OR could be bad venting of your fuel tank, or a partial clog at the pet ****.. the first is pretty easy to check, open your fuel cap and start the bike..if it does the same thing then its not a vent problem. One thing that does happen on the Radian, is the reserve fuel screen inside the tank comes loose, and then everything inside the that has built up over the years either partially clogs the pet ****, or the hose, or both. Take the tank off, pull the pet **** off..if it still has two intact tubes with good screens..you probably don't have any junk in your line..but I would pull the line off and blow through it any way... it could be some type of blockage, when the bike sets the fuel seep through, but when it runs it eventually creates a vaccuum that stops the fuel flow. Those are my two first thoughts... good luck!!
SOURCE: pop noise with thick white smoke from front end,
sounds like you might have a cracked cylinder and oil puddled up inside over night and when you started it..it blew out through the exhaust. White smoke means oil...black smoke means gas ,and blue smoke means both..if you cracked a water jacket your oil will look like a bubbly milk shake.....take a look at your oil.
SOURCE: I have a 2001 Road Star 1670 cc. I was riding the
This is just a shot in the wind but it is possible when it gets hot the Engine Control Module or Ignition Control Module, which ever your bike has, has an open circuit in it when you heat a module up everything expands and could cause circuits to be open when they would be closed when the are cold. I have seen it before in alot of different kind of vehicles not just motorcycles. But that is my professional opinion it is possible it could be something totally different though that is the bad thing about being a Technician. If you have any more question please let me know and leave good feed back please.
SOURCE: bike has new battery and
You should start by checking if its charging.
put a volt meter across the battery, it should read roughly 12v
then start the bike and it should rise to 14v
much more than this can blow bulbs and boil batteries
