Question about Pelican Video Game Consoles & Games
I need to know how and what i need to connect my cobra to my xbox 360 elite plz help
SOURCE:
SOURCE: XBOX 360 Elite HDMI problem
I have same issue with my Xbox 360 Elite using HDMI cable from Microsoft on my Mitsubishi 57" 1080P.
Works fine with component cable upto 1080i, get nothing using HDMI cable.
Posted on Jan 30, 2008
otacon
  • 1950 Answers
SOURCE: INSTRUCTION MANUAL FOR XBOX 360 ELITE
You can download it here from Microsoft.
http://www.xbox.com/en-US/support/systemsetup/xbox360/resources/instructionmanuals.htm
Here is a direct download link.
http://assets.xbox.com/en-us/support/na-console-elite.pdf
Posted on May 09, 2008
Sirach
  • 59 Answers
SOURCE: help with internet conection
If connecting wirelessly are you sure your wireless on/off switch is not accidentally getting turned off and on and do you know how to turn it off and on?
Posted on May 22, 2008
drlalitv
  • 488 Answers
SOURCE: Need to add mac address to router form xbox 360 wireless connection
if its for the xbox then follow this:
. Navigate to the System area of the Xbox Dashboard.
2. Select Network Settings.
3. Select Edit Settings.
4. Select Additional Settings.
5. Select Advanced Settings.
The MAC address will be displayed toward the bottom of this page where it says Wired MAC Address.
hope it helps!
Posted on Nov 02, 2008
SOURCE: need to connect xbox 360 to panasonic sa-mt1
If you want to play 5.1 sound, and you got to need this fiber optic cable(black single cable)..with reciver decoder with optical on IN, to connect the xbox 360 machine on, and the high defintion cable of the xbox.
Posted on Feb 22, 2009
I don t know my xbox 360 family passcode plz help my dashboard 2.0.174390.
Family passcode resets are unique to each console via the serial number. To obtain the correct unlocking procedure you will need to contact MICROSOFT Xbox Support. Where they will want to confirm you own the console and then tell you the procedure to unlock it. DO NOT use another consoles unlocking procedure on you console they are all different. So call Xbox they will sort this out.
Aug 16, 2015 | Microsoft Xbox 360 Elite Console
I have xbox360 elite modd.mfd 2007-10-16.now it shows e73.
it was a bad idea modding your xbox because in order to do so they have to remove a special chip or rewire so the chip is skipped.this chip stopped your h77 turner lap from over heating which is what has happened causing it to leak.you need a new UNMODDED xbox oh and whatch that liquid it,s highly acidic
May 15, 2010 | Microsoft Xbox 360 Elite Console - Black
Keeps saying connect controller,this is a new xbox elite
the problom is your controller , bring it back 2 the shop were u bought it 4 a replacement 1 ,. u can also open it up and fix it yourself but if u dont know how , i wouldnt advise it.
Jan 13, 2010 | Microsoft Xbox 360 Wireless Controller
How do i use a hdmi cable on my xbox360 elite
Purchase an HDMI cable, connect one end to the back of your 360 elite, connect the other to the back of your television. Power up your 360. If there are other issues, please let me know and I will do my best to assist you
Nov 16, 2009 | Microsoft Xbox 360 Elite Console
Xbox live party
your nat type is strict you can change this by opening up your internet explorer go to tools then internet options and make the needed changes
Apr 07, 2009 | Microsoft Xbox 360 Elite Console - Black
Xbox 360 elite 1 red light
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The number for Microsoft is usually listed on the back of any game manual.
I hope I was able to fixya problem, and Happy Gaming!
Oct 18, 2008 | Microsoft Xbox 360 Elite Console
Xbox elite
You need to enter the router configuration. How you do this varies by model, but usually involves typing your gateway address into a web browser. Then, you need to assign your xbox an internal IP address and activate port triggering or forwarding (depending on the sophistication of your device) to send information on the designated ports to the Xbox.Was this solution helpful? Show your Appreciation by rating it RICHARDM69
Jun 11, 2008 | Microsoft Xbox 360 Elite Console
Xbox 360 elite
hey do u have the rite cables and do u have dsl if u have and alarm hooked 2 the phone line that might be the problem also
May 25, 2008 | Microsoft Xbox 360 Elite Console
Xbox networking
you will have to set ftp up m8 you need ip of the xbox and fast transfer protocol program transfer as data or image theese files need to be made to image using ultra iso on pc first all xbox uses is linex
Nov 13, 2007 | Microsoft Xbox 360 Elite Console
Video Game Consoles & Games Logo
46 people viewed this question
Top Pelican Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Pelican Video Game Console and Game Expert? Answer questions, earn points and help others
