Question about Hisense 50 Class LED HDTV - 1080p, 1920x 1080, 120Hz, 3x HDMI - LTDN50K360GUS - LTDN50K360GUS
Tv not working
Black screen and no sound just started today..
I have a 55 inch JVC tv,today the screen went black but still have sound, also the buttons on the back wont work, but the channel down button turns it on and off? What is wrong with it?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary..
Jan 15, 2017 | JVC Televison & Video
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
Why does the screen shut down after 1 sec while sound continues
It sounds like bad luck to me. You cannot change any settings on a TV by connecting a computer to it. In theory you can damage any monitor by setting the screen resolution of the computer higher than the monitors maximum res. The Sharp 26" has a resolution of 1366 x 768 (1080i) so (again in theory and I have never seen it happen) if you set the output to 1920 x 1024 (HD - 1080p) it can kill the screen. Perhaps this is what has happened. You will need to take it to a Sharp service centre.
May 29, 2014 | Sharp LC-26SD1E 26 in. LCD Television
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
How do i fix a vizio 42" tv with a black screen, no sound
THE MAIN BOARD AV BOARD HAS WENT OUT JUT HAPPENED TO ME TODAY
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/shawn_b2b2e24a98865a53
Feb 28, 2013 | Vizio Razor M421nv 42" 1080p Hd Led Lcd...
Screen started to go black while watching the tv.
yes, by canging the bulb. it proboly went out while the television was already dead. you can try but i would hire a proffesional. it may cost 100$ or more.
Oct 11, 2009 | Philips 47PFL3603D LCD TV
FullHD KDL46XBR2 Bravia: No pic, no sound
call a tv place and order a lamp for it if your not old to lift it
May 19, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Mitsubishi VS-50501 - Black Screen
Is the power light staying on? If so press imput and menu together for 5 seconds to see if the set will blink a 2 digit repeating code. If that doesnt work. Check for CRT coolant leaks on the boards. This seems to happen alot as do faulty capacitors. Coolant leaks will be located on the chassis directly under the tubes they can cause corrosion and prevent your set from starting especially in the VS models.
Dec 30, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Hisense 50 Class LED HDTV - 1080p, 1920x 1080, 120Hz, 3x HDMI - LTDN50K360GUS - LTDN50K360GUS Logo
29 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
