ASUS ME400C-C1-BK 10.1 in. 64 Logo
A
Anonymous Posted on Apr 04, 2014
Server's securty certificate errors - ASUS ME400C-C1-BK 10.1 in. 64
1 Related Answer
Anonymous
  • 821 Answers
  • Posted on May 21, 2012
SOURCE: company has a windows remote server 2011. I have windows 7 with ie9. I keep getting certificate errors. I have tried to move it.
this is a clear administrator rights issue you need to resolve with their admin folks. certs are operating system dependent and none of us in fixya have any access to your network server
How To Fix Outlook Error 8?
Outlook is unable to connect to the proxy server, probably because of certificate issues. You need to correct the certificate problem...see the link for details. https://technewskb.com/outlook-is-unable-to-connect-to-the-proxy-server-error-code-8
Company has a windows remote server 2011. I have windows 7 with ie9. I keep getting certificate errors. I have tried to move it.
2helpful
SSL certificate error : SSLPassPhraseDialog builtin is not supported on Win32 . Please Help
Generate Keyopenssl genrsa -des3 -out startssl.key 2048Remove Pass Phraseopenssl rsa -in startssl.key -out server.key
Generate CSRopenssl req -new -key server.key -config "c:\xampp\apache\openssl.cnf" -out server.csr Configure it
give csr at startssl and get certificate and run ... BEST OF LUCK
Useserver.key and certificate u got
16helpful
How to install ssl certificate on ACS 32
Installation of a certificate on Cisco ACS Note: ACS only supports PKCS12 certificates. Before installing a certificate, ensure that the certificate is of this type.
To install a signed certificate: Step 1: Choose System Administration > Server Management > Certificate.
The Certificate page appears.
Step 2: Click Install Certificate.
Step 3: On the Install Certificate page, enter values for:
• Server Certificate Format
This is a display-only field, and displays the PKCS12 certificate type.
• Server Certificate File
Enter the path to the local directory in which you saved the certificate file; optionally, click Browse.
• Private Key Password
Enter the private password key, which can be up to 32 characters.
• Confirm Private Key Password
Confirm the private key password.
Step 4: Click Install.
Step 5: To activate the certificate, you must restart all the processes on the ACS View server.
To restart the server from the:
•GUI-Choose System Administration > System Reports > Process Status, and click Restart ACS View Server.
•CLI-Access the CLI in the EXEC mode, and run these commands:
-process stop all
-process start all
regardsSandeep
I am having problems connecting VPN Connection on my Windows 7, it says there need to be a machine certificate installed before i can connect using L2TP/IPsec. error code :766
"Error 766: A certificate could not be found. Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate."
"Error 766: The L2TP connection attempt failed because the security layer could not authenticate the remote computer."
Cause: Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate. You will see this error message when such a certificate is not available.
Typically, this error is generated on a remote access server that has active L2TP ports configured, the remote access service started but there is no certificate in the computer certificate store. This generates an event log message that tells the administrator that L2TP ports will not be able to accept calls until a certificate is acquired and RRAS is restarted.
Resolutions: 1. If you use PPTP VPN, select Automatic in Type of VPN.
2. If you use L2TP, check the remote access server and make sure there is certificate in the computer certificate store.
3helpful
Certificate error on web site.
This is basically an Internet Explorer 7 Website’s Security Certificate problem! You have to self-sign the certificate on the client computer or add the URL manually to the trusted security zone. When you are trying to access a secure web page, you receive the warning message:
"There is a problem with this website's security certificate. The security certificate presented by this website was not issued by a trusted certificate authority."
Or
"Security certificate problems may indicate an attempt to fool you or intercept data you send to the server."
To fix this issue, you can follow either of the methods:
Method 1:
You have to install the Microsoft Windows Small Business Server 2003 (Windows SBS) self-signed certificate on the client computer. To do this, follow these steps:
  • In Windows Internet Explorer 7, click Continue to this website (not recommended).
A red Address Bar and a certificate warning appear.
  • Click Certificate Error button to open the information window.
  • Click View Certificates > click Install Certificate.
  • Click Yes, to install the certificate, when warning message appear.
Note: For Windows Vista users, right click on Internet Explorer icon. Select Run as Administrator.
Back to top
Method 2:
Add the URL to the Trusted Sites security zone:
  • Open Internet Explorer
  • Go to Menu bar > Tools > Internet Options.
  • Click Security > Trusted sites > Sites
  • Type the URL in the Add this website to the zone text box > uncheck Require server verification >Add > click OK
  • Click OK to exit.
Now you have added the URL successfully into the Trusted Sites security zone.
I tried to log into twitter and some error I've never seen came up also the same on my hotmail and facebook account. Have I been hacked ?? here is acopy of the message Secure Connection Failed ...
If you are using Mozilla :
Click Tools > Options >Advanced > Encryption > View Certificates.
Delete Certificate related to Twitter and Click ok and close the boxes.
Download certificate the next time you are prompted to download.
1helpful
2answers
SSL Certificate error:Certificate Mismatch
Go to IIS and right click for the domain where you wish to delete the old certificate associated with it.
Right click website from IIS and click properties. From the Directory Security tab. In The Secure Communications click Server Certificate to open the Webserver Certificate wizard. Click Next and choose "Remove the current certificate". Click next until you follow the end of the wizard.
2helpful
Gmail, Blogspot & Googletalk
hello, this is the problem with the SSL security certificate.. to solve this problem in firefox ... first when this error is displayed there wil be a link that says " add this certificate " , click that link and add the certificate to ur browser.. the problem will be solved ... or else go to internet options in ur browser and check for certificate settings .then download the certificate from google with the option given there....
Feb 03, 2009 • Google Talk
Top ASUS Water Sport Experts
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you an ASUS Water Sport Expert? Answer questions, earn points and help others
