Lands Phones Logo
A
Anonymous Posted on Apr 03, 2014
Need to reset mailboxs at once - NorStar Lands Phones
Nortel phone - VM box locked contact admin - tried solutions & no luck
Hi Lyndsay,
Have you tried feature 985, and then press 9, and enter the passed resetsmppwd? That should reset the login on feature 983 to 1020000 for three digit extensions, or 102000 for two digit extensions. Once you get into there, you can reset the mailbox password for the general delivery mailbox. Depending on your system, even though the general delivery mailbox might be on extension 363, the mailbox number is likely to be 100.
Voice mail locked after various attempts at putting wrong password in. How do I rectify?
Your mailbox is assigned a maximum number of incorrect password attempts.
Norstar Voice Mail records the number of incorrect attempts from the last time your mailbox was successfully accessed. Once the number has been passed you are"locked-out" Your mailbox cannot be opened again until the System Coordinator resets the password
We have a KX-T7630 phone and we are trying to reset mailbox password but it won't work. We tried to delete password by accesing mailbox 999. We went to Other features Mailbox Setup . Reset Pas
You need to set a specific password. Probably in RESET password, it's reset to a default value, so if you don't know what the default is, then you can't use it. We usually use x(plus your extension), where x is like a digit 3 or 4, but I didn't install yours :-)
Carl
Mail box locked tried to reset no luck
All you need to do to unlock the mailbox is to reset the password. If you're having no luck, it's because you're resetting the wrong mailbox. Make sure the mailbox you're resetting is actually assigned to the proper extension.
Usually, the reception mailbox is mailbox 100, regardless of what the actual extension number is.
8helpful
I used feature 983 to delete a few old mailboxes. Once I completed that, I no longer had access to features 983 or 981, because it is now telling me that my passwords are incorrect. How do I reset these...
It sounds like you've either deleted your own mailbox or reset the password to 0000 and changed the password to the administrator mailbox. To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000. 1020000 if you have 3 digit intercom numbers. Once that's done you can go into admin programming to default your password back to 0000.
3helpful
I locked myself out of my voicemail for Norstar M7310!
Feature 983 is system admin
1. Log into system administration
To Reset a Mailbox Password:
2. Select the softkey under “MBOX”
3. Select the softkey under “Chng”
4. Enter the mailbox number you want to reset the password for
5. The display shows “Reset Password”
6. Select the softkey under “RESET”
7. Press the release key
*The new password will be “0000′, the system will ask the user to change
2helpful
4answers
One of my co-workers mailbox is locked.
Delete the mailbox, once deleted, add the mailbox again.
2helpful
2answers
Lost voicemail on phone system Norstar T7316E
So, voicemail does not pick up or answer at all?
1helpful
MAILBOX LOCKED
try 1021234, 1024321 next. The default password to the mailbox to the locked box once you have reset will be 0000.
Mark
[email protected]
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
