Solenoid Brake Trip
The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the system connections are secure.
check that the free wheel lever is disengaged, alway switch off the controller (joystick) before making adjustment or unplugging connectors as the error code will not clear until the joystick is switched off and on again. check connector blocks and wires for damage or being dirty contacts. clean use soft wire brush to clean the connector contacts.
