SOURCE: electrolux ewx14440w starts but then turns off no
check the motor or heater is not down to earth. you need 500v insulation tester for this.
SOURCE: electrolux ewx14440w washer dryer will not heat water
Hello - Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well. After confirming information and it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a defective timer, temperature sensor, or water valve.
