Freezers Logo
A
Anonymous Posted on Apr 03, 2014
Samsung SR-S20 replace water filter - Samsung Freezers
After replacing filter, how long before filter light goes off?
Filter indicator : The filter Indicator will be Red when you have used your water filter for 6 months, Reset the indicator (it will be Blue) after replacing the filter by holding the "Alarm/Hold 3 sec for Filter Reset" button for 3 seconds.
The above is how to reset the indicator
1helpful
Get replacement water filter for refrigerator
Most appliance stores that sell this fridge have the accessories for it. Additionally, big box stores like Home Depot, Lowe's, etc. along with larger hardware chains (TruValue, Aubuchon, etc.) will likely either stock them or be able to order those parts. Finally, there's eBay & Amazon.
Samsung french door refrigerator wont disense water after replacing water filter
Put the old one back in and if water works, then the new filter is blocked. Buy another filter.......
Water flows very slow out of the dispenser on my samsung refrigerator
Try replacing the filter again, If it works again then you might want to think about putting some sort of water softener system in your home
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
1helpful
Refrigerator RF323TE how do I change the water filter?
The filter for the french door refrigerator is probably behind the vegetable drawer, if you do not see it in the upper right hand corner of the refrigerator compartment. Remove the veggie drawer and turn off the water coming into the refrigerator. Rotate the old filter to the unlocked position and remove it. Then take off the protective cap from the new cartridge and insert it into the refrigerator. Rotate it to the locked position. (Rotate the filter to position the label before you insert the filter. Then the filter goes in correctly.) Reinsert the vegetable drawer and close the doors. Then turn the water back on and fill several glasses with water to clean the filter. Pour that water down the drain at your sink.
For pictures of how to hold the filter, see http://www.samsung.com/us/support/owners/product/RF323TEDBSR/AA . See the FAQ on replacing the water filter. I hope this helps.
How do I change the water filter for the refrigerator, Samaung RF323TE
Page 13 of the User Manual explains where and how to change the water filter RF323TE User Manual
Click link below for instructions
Where Is The Water Filter And How Do I Install It on my French Door or Side-By-Side Refrigerator?
Or click HERE If you have questions or trouble navigating the Samsung site please ask questions and I will try to assist you, Thanks Sea Breeze
1helpful
Samsung refrigerators
if the filter is dirty enough to where it stops the flow of water then yes.a replacement of the filter should fix the problem for you
1helpful
Orange light in the shape of a leaking bucket. Side by side fridge/freezer with ice maker and water dispenser
I think you are referring to the water filter alarm. When it first starts coming in, you only notice it when you blink. As time passes, the color becomes more pronounced....If this is right, we'll move on from here, if not, please re-post, and please don't mention the village idiot (me).
The alarm can come on if a high differential pressure is sensed across the filter, or it can come on at pre-programmed times. If the fridge is relatively new, and the quality of the water is good, you can reset the alarm. On my model, I hold down the "ice type" and "child lock" buttons for about 5 seconds. The actual filter is located in the fridge, on the upper right hand side. These filters are somewhat expensive. I say that to say this....You can extend the life of your filter by installing an in-line filter between the wall water valve and the back of the fridge. This will act as a pre-filter for the Samsung filter. They cost usually about a quarter of the cost of the Samsung filters, and are easily replaced. Should you decide to replace your filter, Ebay is a very good source at a less than retail price.
Hope this was what you needed...regards --W/D-- Please feel free to rate this solution!
Jul 28, 2009 • Freezers
8helpful
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 • Freezers
Top Samsung Freezers Experts
Jay Finke
Jay Finke
Arnie Burke
Arnie Burke
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
