The phone wouldn't accept gmail or anything else
If it is stuck or frozen:
Do a Soft reset
Occasionally, you may need to reset your device. A soft (or normal) reset
of your device clears all active program memory and shuts down all
active programs. This can be useful when your device is running slower
than normal, or a program is not performing properly. A soft reset is
also necessary after the installation of some programs. If a soft reset is
performed when programs are running, unsaved work will be lost.
To perform a soft reset
Use the stylus to press the RESET button found at the bottom of your
device. Your device restarts and displays the Today screen.
Or:
Do a Hard Reset
(THIS WILL REMOVE ALL APPS BUT NOT YOUR PICS AND MUSIC!!)
This will wipe your device to factory reset. You will need to log in to your gmail account like you initially did.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
I found the following on another website. I don't know if it's true.
One thing unique about Android phones is their pattern unlocking system. However, after a number of unsuccessful tries, it will lock you out permanently. This happened to my brother, and it wouldn't accept his gmail username and password (the only other login method). He was looking at a reset and loss of all his data not stored in his Google account. Luckily, he found a work around. If you enter your gmail account name, and use "null" as the password, it will enable the pattern unlock again.
This may give you a chance to try different patterns until you find the one you set.
Step to setup an email account on Samsung wave:
1. Press Menu
2. Select My Accounts
3. Choose the type of email account you want to
configure . For Gmail, select "Google "
4. Enter your e - mail address and password and
click " Next "
5. A new window pops up. Select apply without
making any changes.
You will need to configure your
Gmail for IMAP or POP pushing first before authorization is given to your Wave
to accept the pushed mail.
Login to Gmail -> Setting (top right hand corner) -> Forwarding and
POP/IMAP -> Check Enable POP for all mail arriving from now on and check
Enable IMAP.
You are done with configuring GMail side.
Now, add your google mail account under "My Account".
Enter your email (username will be filled up automatically), then your
password.
Next, when you hit the next screen, DO NOT CONFIGURE ANYTHING. Simply
"Set".
Make sure u have POP and SMTP enabled in your mail account before
you try this and yahoo users make sure u enter your mail address as that of
your domain
example : [email protected]
where xx can be something like uk or us or in etc
I can't even login to my gmail for the first time. It is unlocked and I am using an ATT sim card.
