I removed the hard drive (Hitachi DK23EB-40) from my old laptop which die and put in a portable case. Issue: The drive is detected (E) w/ some of the manufacturer files. However, my personal files are not detected or displayed. When the drive is connected to any computer it displays "installing device driver software" which last forever with no resolution or ending... And There seem to be no drivers availabe for this drive. Any solutions that can help bring resolution would be appreciated to allow me to access my files. Thanks in advance.
Have you put the hdd from the laptop into slave mode, its on the back of the hdd, there might be a "jumper" that you need to reposition, failing that only insert the 1 hdd from the laptop and make it the only hdd, it should have an operating system on to run as normal. You can see the <jumper> on the right of this picture, you will need to connect both teminals (slave) with a little plastic jumper.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Hi John Dowson, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
What OS you had on your laptop which die and what are you using now
