LG HBM 730 Bluetooth Headset Wireless Headset Logo
Gari Canonico Posted on Apr 03, 2014
Wont power up
Once cgarged i get no power or b lue light
I need a Luen Ming LM-132 Breakaway Electric Magnetic Power Cord 15A 125V. I can't find New unused at all. I've tried every site imaginable and can't find one.
I can tell you have found USED such cords on Ebay. I suspect your quest for a NEW one is best directed to the company Lue Ming Electric Works Co. Ltd which is based in Hong Kong. Here is their webpage: http://www.luenming.com.hk/index_topic.php?charset=eng&did=76074&didpath=/75489/76074
Do i charge it with it on, i cgarged it for 4 hours and after 30 minutes it said power off
The battery may be losing power. Charging it off will take less time and charge to a higher level.
My LGL55C powers up and goes to the b lue screen n won't boot up or do anything won't turn off .
Dear Chris,
Seems like a bad RAM. Simply change your RAM and then give your laptop a go and it shall be all fine and smooth sailing on wards. You can test it by simply borrowing a RAM from your friend for a while. But do make sure that RAMS are of same type.
3helpful
There shouldnt be anything wrong with cannon g9 camera but even when i let the battery cgarged for more than a day the camera still wont turn on what should i do?
You likely have a very common no power problem that sometimes comes up on the Canon Powershot G9 Camera. It's caused by two screws inside the camera that come loose and make it short out. You need to have it serviced and that problem is not much at all to fix. If you go to: camerasandparts.com they just specialize in service for the Powershots. They're amazing if you need some help with one of these. They have a deal for $89 total with return shipping and that covers the total service and repair, plus they include a fix on all the G9's so the short never happens again. Best of luck, that's too nice of a camera to not be turning on.
Tom tom plugged in , green light on but can't
cgarge it up good for about four hour via the usb cord provided with your unit, then press and hold the power button for up to ten seconds.
2answers
Headphones change batteries
Any luck with that model number??
Top LG Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
