SOURCE: 5 flashes amber pixma ip3000
5 flashes amber means the print head is not installed properly (error code 1401) or the EEPROM data of the print head is faulty (error code 1403 or 1405).
Make sure the contacts on the printhead are clean, re-install and try again. If this fails a new printhead may be required. You may be able to re-initialize the EEPROM by entering the service mode.
SOURCE: Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
SOURCE: Canon Pixma iP1800: amber, green, amber, greeeeen flashing lights
what error message coming from your computer...i think something stuck inside your printer
SOURCE: power light flashes green once then amber 7 times
change/clean manually the main roller because it observe ink.
SOURCE: when i turn the printer on the light flashes amber
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
