Computers & Internet Logo
G
Gul Ahmad Nazari Posted on Apr 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How use extra batteries with more than 100 AH in MGE UPS Pulsar 1000?
I want to use mentioned batteries, but my UPS doesn't support charging regularly; what to do?
Mike M
Level 3:
  • MGE Master 3,349 Answers
  • Posted on Apr 04, 2014
 Mike M
MGE Master
Level 3:
Answers
3349
Questions
0
Helped
686759
Points
16707
You can't with that model.
  • Tahir Sarwer
    Tahir Sarwer May 03, 2014
    I have Mercury Classic 600 PRO UPS. i want to know how much Ampere of battery will be sported by this ups
mestrada642
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Apr 29, 2014
mestrada642
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
7955
Points
26
You can`t becase the battery charger is not big enough to charge such big capacity batteries.
Unless you install an external battery charger only for the external batteries, the batteries should be connected in parallel with internal batteries but with a diode to avoid the internal charger to try to charge the external batteries.
BUT, you can not parallell batteries of different capacity. I don`t remember the maximum capacity of external batteries, but let`s assume that it can charge 34ah batteries, what you can do is remove internall batteries, install a first bank with 34ah batteries, and install aditional 34ah banks in parallell to get more backup time; this aditional banks, sholud be connected with a diode in series so that the internal charger charges only the first battery bank.
I hope you understand this explanation, please feel free to ask if there is something that you don`t understand.
1 Related Answer
A
Anonymous
  • Posted on Oct 09, 2008
SOURCE: MGE UPS Pulsar EXtreme 1000 C
I three
Pulsar UPS DC bus too high
where did you find this old UPS> ? I'd bet cash it did not just fail 14 years online TODAY.!?
Redux1 this is way too long but there are many sub models of PULSAR and non told yet. by you.
nor if TOWER OR RACK MODEL is your? wow. that. ? not the same batteries at all in both ever.
did not read your manual first.
14 YEARS old it is, and now owned by APC.com (a 2007 event)wiki it.
The HIGH DC means the Charger output is too high
or the 36v 3 battery loop is broken (no load equals charge voltage is too high DC bus)
if you have rack UPS and use 12vdc batteries, in it (not 6vdc as it must) the DC bus will be too high.
UPS is complex and more so not telling full model numbers of it and photo of if.
the LIST OF what can be wrong, (besides bad PCB inside)
wrong batteries, used, or connected wrong.
battery terms rusty. or just loose.
EXB option was enabled before (14 years ago?) and not reconfigured now that it is gone. now.
battery breaker rear tripped. in inside batteries and if EXB option the outside battery breaker tripped. on it.
wire backwards is prevented with connector keys, but if hacked , any thing is possible wrong,.
no photos of yours, the DC bus is 36vdc on the tower. 3x12=36v
AC LINE IN CAN BE SET 100VAC TO 480VAC, (TO COVER WORLD POWER USED)
if not configured day1, correctly there is no hope, only smoke.
what AC voltage is your country, (at home are you) and freqency, 50 or 60HZ, (most are auto set for Hz)
MGE is nOT MEG. at all. sorry but typos like that make help super hard.
just one of many 1500, I can not guess what your REALLY is, Pulsar has many sub models.
https://www.manualslib.com/manual/821986/Mge-Ups-Systems-Pulsar-Extreme-1500.html?page=1#manual
MGE is now owned by APC for 14 years today, UPS company (a top maker)
and this model is not supported now it is too old,,, found in garage sail for $1 USD, I'd pass on that.
and APC does not support this very very old UPS now. they chose not to support it, but gee call them and ask.
Apc.com, click support , and contact them.
next time post photos of front and rear.
and full model number not just "Pulsar 1500," shortened like that. and MGE not MEG.
and what country you live and if at home or using commercial power , 100v or 480vac or what. LINE POWER.?
last , is , if you buy a used UPS outside of your country it will be wrong AC input line voltage. and must be cured first. by strapping or configuration settings,
I have never seen any UPS made that works in all countries, and the few that do many, must be strapped first.
how that is done is covered in every UPS MANUAL made, in the world.
if done wrong this test step, you will get smoke or worse fire. (only fuse can save you from that done wrong)
never bypass fuses OK
and if doing other hacks say so, tell the hacks , like using the wrong batteries.
MGE Pulsar 5000 - environment fault
Go to enter bouton in front of the ups and read the fault code if it's a temporary fault when you try to read the ups show that you have to press 3s to reset
Please can you tel me whitch Kind of battery, and how many battery there is in this model : MGE PULSAR EXTREME 1500C RACK and MGE PULSAR EXTREME EXB 1500C RACK
Specifications for MGE Pulsar Extreme 1500 C 2U Rack Battery kit
Voltage 12V (Per Cell) Capacity 6Ah (24W) Weight 8Kg Dimensions 151mm x 94mm x 51mm (Per Cell) Lifespan 3 - 5 years Type Sealed Lead acid battery rechargeable highly efficient, leak proof and maintenance free
I think there are four batteries in the pack.
1helpful
I have MGE pulsar extreme 3200c and I wanted to know that what is the Max battery size (Ah) I can use with it to get Maximum backup time for several hours. Thank you Azam Latif
Hi, I have this ups as well, My personal adjustment with this ups, is I have installed 6 external Ags Number 120, 15 plates per battery, in pairs. And its working fine on my end , and yes ups is able to charge them all without over charging or any other problems. My ups Already has 6 internal batteries bank installed, attaching these external batteries has increased the backup time.
Thank You.
1helpful
What software do I need to connect to my MGE UPS Pulsar EXtreme 1500C?
The Personal Power Pack (UPS_psp_2_60_02.exe)is the best for MGE UPS,but it has been discontinued for a long time and it runs only on XP and older windows os.
For adjusting the advanced parameters of the UPS,u can use the upsdrv15.exe. This software works only with serial connection.
The only solution for Windows 7 is Eaton's Lan Safe software (since Eaton bought a part of MGE,the UPS is recognised by their software).
These software are not very easy to find,but they're there.
Hello, could you please let me know the battery type of MGE premium ellipse pulsar 800VA ups? Thanks in advance.
The batteries in an UPS are sealed lead acid batteries. The voltage and amp hour rating depends upon the VA rating of your UPS.
I suggest you shut down your UPS and remove the batteries and get replacement ones that are the same rating as the ones in the UPS. Be careful of the size of the battery, they are a neat fit inside the UPS battery compartment.
2helpful
My mge 1500 ups is indicating fault behind with an led flashing red and there is no output from the ups with or without ac input
My mge 1500 ups is indicating fault behind with an Problem with the MGE UPS Pulsar Evolution 1500 UPS System my mge 1500 ups is indicating fault behind with an led flashing red and there is no output from the ups with or without ac input
What can we do if in my mge ups (pulsar mx) is displaying dc bus low shutdown?
Prag board(main board ) not working properly . Replace the board to solve the problem.
4helpful
2answers
Mge pulsar 3000 does not power up
MGE Pulsar 3000 is an online UPS. try to check the battery first if its ok. coz for an online UPS it will need to have a good working UPS battery to trigger the switching relays to on the online UPS unlike backups UPS that can be turn on without any batteries
Top MGE Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
