Question about Canon FS400 Camcorder
I have a canon fs400, the battery is fully charged but the camera wont turn on
SOURCE:
  • 3 Answers
SOURCE: my canon zr400 wont turn on
ITs most likely a fuse, unfortunately you can change it or its a son of a gun to change. You can check by removing the motherboard, locate the fuse, they are micro fuses, it either has the letter H or K etched on it, there could be anywhere from 1-5 of those fuses. Check for continuity if that s the problem than replace it, if you cant find a replacement micro fuse than solder over the fuse for continuity...that should make the camcorder power on, but beware once you solder over the fuse- there will be no more current protection for the camcorder. If the fuse is not the problem than it could be a loose circuit...
Posted on Apr 02, 2008
t00nz
  • 4738 Answers
SOURCE: Canon Powershot A540 - Change Batteries when Batteries Fully Charged
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Posted on May 28, 2008
  • 35 Answers
SOURCE: camera wont turn on
Camera will not power on. Canon posted a bulletin regarding a possible solution for some SD950's at the following website. Apparently this model has a screw that can come loose inside and the camera will not power. They just found this to be the case with my SD950, and they fixed it for free. It was outside of the warranty by a couple months. They even sent me a prepaid UPS shipping label to send them my camera for repair. See the link below for more on this possible solution:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=224&modelid=15652&keycode=2112&id=55260
Posted on Mar 26, 2009
  • 57 Answers
SOURCE: Canon G10 wont turn on
Try removing the card first and then trying to power up the camera. Cameras often fail to turn on/off when a card goes faulty. Next I would try pushing the playback button, it also acts as a power button but starts the camera in playback mode. If this works it could indicate a problem with the power switch circuit itself. If there is still no sign of life I would suspect a fuse to have blown. They are internally located and very small, you would need to have a service centre try replace it for you. Good Luck!
Posted on Apr 15, 2009
tscmusa
  • 95 Answers
SOURCE: My Canon ZR400 Digital Camcorder would not charge
It needs to go to Canon for service.There is a internal component failure
Posted on Mar 26, 2010
Import video files (mpeg, mp4, etc..) to (mod.moi) canon fs400
Visit www.download.com (part of CNET), and search for 'video convert' You'll see dozens of programs that can do the job. Make sure you select one for your OS (Windows, Mac, etc.), and be aware that there are both 'free' and 'trial' programs there to try. Also, read EVERY screen when installing, being sure to UNcheck any optional stuff you do NOT want (toolbars, new browsers, etc.).
http://download.cnet.com/1770-20_4-0.html?tag=mncol%3Bsort%3Br&query=video+convert+.moi&searchtype=downloads&filter=licenseName%3D%22Free%22'platform%3DWindows%2CMac%2CiOS%2CAndroid%2CWebware%2CMobile&filterName=licenseName%3DFree'platform%3DWindows%2CMac%2CiOS%2CAndroid%2CWebware%2CMobile&sort=&rpp=10
Dec 02, 2013 | Canon FS400 Camcorder
Ihave a Canon PS SD 750 digital camera, that wont start, even with a fully charge battery? Is this a battery problem?
I believe your camera's software will have to be updated. You can probably download the update from Canon's website.
Apr 17, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
  • Direction of your battery might be wrong, Check out and put it again.
  • Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
  • Check whether Memory Card/Battery Cover is properly closed.
  • Load new or fully charged battery.
  • Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 05, 2010 | Canon PowerShot SD1000 Digital Camera
Won't turn on!
Had that problem too in October (during vacation in Sardinia); had to return the camera to Canon for repair. They noted a change of circuit ...
It 's now fully operational again
Aug 02, 2009 | Canon IXUS 960 IS Digital Camera
Help
Wow, this is trully amazing. I went to do a search on why my camera wouldnt turn on the past couple of days, even after i charged all THREE of my batteries and found similar complaints within the same time frame!! WOW. We need to get together and fight this, cause its suspect!!! I bought mine in Mass, anyone else?
Jun 30, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera wont turn on **** battery is charged
My Ixus 960 IS will not turn on even with both batteries fully charged. Any suggestion as it looks like a common fault?
Regards
Moooch
Jun 23, 2008 | Canon IXUS 960 IS Digital Camera
Canon FS400 Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
