Split System Air Conditioner
Considering this, what does Ch mean on LG air conditioner? It is not a problem but it is just the reminder to clean the filter of the air conditioner. ... LG Split System Air Conditioner Error code = 05 LG AC Fault Definition = Communication(Indoor Outdoor) - Communication Issue. Indoor Status = Off.
CH 5 on these units indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assembly to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts. 800 243-0000
CH-05 Communications Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
CH-05-Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
