SOURCE: hi, its about my N73 lock code
The default security code for Nokia is 12345
IMEI: 356406013883474
Master code: 0615326066
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer via an unlock box to restore the Security code.
SOURCE: Forgot phone lock code
we need ur imei number to help u....
kindly post ur imei number it will be a 15 digit number on ur phone battery slot... once u remove ur battery u can see it...
thank you
have a nice day
SOURCE: forgot the phone lock password ..
Hi,please dial this code on your phone, *#7370# code.This is a hard reset code,
Thanks and take care
SOURCE: i forgot my password in
Hello Sajid,
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FE Explorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file.
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
