Most common problem is the IAC(Idle Air Control) valve.But if you say some times work I will suspect the throttle is clogged. Remove the Air hose,apply full throttle and hold, spray carburetor cleaner on clot using thin long nose player clean inside wall and throttle. don't spray directly inside because the carb cleaner is to aggressive for some of the gasket.
Good Luck
SOURCE: car stalls when accelerating in low gears
I had similar issues on mine. I bought it from the Good Will for less than $1000. :)
It's been totaled i believe at least twice.
Anyways, replace the fuel filter. It's about the size of an oil filter and is very easy to replace.
Also, replace the spark plugs with some good titanium type plugs. They're like $4 from Wal Mart.
Next, put some fuel injector cleaner every other tank of gas or so. This will definitely help.
Good Luck
