Hi My sister has gifted me Onida 32" LCD TV on my wedding i.e.2012. but after 1 year TV is automatically switching off frequently. I changed Power supply board, Main board circuit by spending almost Rs 9000/- but still problem has not been solved can you plz tell me any solution so that I can resolve the problem. Onida is not having well experianced engineer with them so I will not go for their service. As it is just wastage of my money. please tell me how reset its factory settings. I hope atleast it will work for it.
I did indeed try to find your set...
Close as I could come without a model number
was LCD24MMS even though manualslib said there was a lcd32mms I could not find one...
There does appear to be a sleep timer on page 2-7
Page 2, part 7...
TURN IT OFF...
Onida LCO24MMS Instruction Manual Page 2
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: latest onida tv service code
sir ineed the service menu code for onida tv remote model is rc 115/d
2879,2675,2819,2909 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
