It weighs [111] lbs
Codes to check are, 2086,2091,2004,2007. If you wish to get more codes and other details check: http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Tv universal remote have it limted to it used and operations,only operate the basic only like power on/off and channels up/down also volume up/down that about it.The tv input video 1 or 2 for IN tv to used are tv personal funcstions only for the tv original remote control only have it functions for.Try the website Remotes.com to buy the tv original remote.
The fuses are located on the inside of the set, remove the back cover and follow the power cord in, there should be a main ac fuse near the cord on the circuit board. Toshiba usually has a second fuse further up the power supply.
This symptom is characterized by a thin horizontal line in the middle of the screen. This symptom is caused by the absence of the deflection sawtooth current in the horizontal deflection coil.
The trouble is easily isolated by a continuity test and by checking the most likely defective components such as A)open vertical linearity compensation transformer, B) open capacitor and C) open horizontal deflection coil.
Be sure to decrease the brightness first before trouble-shooting if the line is very bright,as it burn the phosphor screen..
