Question about Minolta bizhub 180 Black and White Copier
What would be the genuine problem when konica minolta bizhub 215 shows maintainence call(m2)
What would be the genuine problems when konica minolta bizhub 215 shows maintainence call(m2)on a menu bar
    President:
  • Minolta Master
  • 1,447 Answers
Procedure
1. Press the COUNTER.
2. Press the following keys in this order:
STOP 0 0 STOP 0 1
3. Enter the code number corresponding to the function to be used from the KEYPAD.
4. Press the START.
<Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Posted on Jul 23, 2014
SOURCE:
  • 126 Answers
SOURCE: Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Posted on Jan 07, 2009
  • 26 Answers
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
Posted on Feb 21, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
SOURCE: ERROR C0910 KONICA MINOLTA BIZHUB DI 2010
2nd Drawer Lift-Up Motor Failure - The Lift-Up Sensor is not unblocked even after the set period of time has elapsed after the paper liftup operation for the drawer has begun.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Posted on Nov 27, 2009
firecontrol7
  • 6850 Answers
SOURCE: konica minolta bizhub 350 error code c5352
Cooling Fan fault. To clear open and closer the front door.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Apr 04, 2010
How to clear on shown display in konica minolta maintenance call m2 call service
Konica minolta bizhub 215 showing maintenance call(m2) and service callProcedure1. Press the COUNTER. (UTILITY)2. Press the following keys in this order:STOP 0 0 STOP 0 13. Enter the code number corresponding to the function to be used from theKEYPAD.4. Press the START.< Exiting the Mode>
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply countthen ok to clear. On/ Off the machine it will work as usual.
Sep 05, 2018 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 164 showing M2 maintanaince call
You need to replace 1st the consumables before simulation/reset to prevent further damage to Bizhub 164.
Dec 21, 2014 | Konica Minolta Office Equipment & Supplies
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply count then ok to clear. On/ Off the machine it will work as usual.
Apr 03, 2014 | Minolta Office Equipment & Supplies
Konika minolta bizhub 215 error code m2
You need to go into the service mode and then reset the supplies life counter.
Feb 02, 2014 | Konica Minolta Office Equipment & Supplies
Desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
May 18, 2010 | Konica Minolta bizhub 161f All-In-One...
Open Questions:
See all Minolta bizhub 180 Black and White Copier Questions
Minolta bizhub 180 Black and White Copier Logo
350 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
