Question about Life Fitness Exercise & Fitness
Sr225 is distnace in miles or km
If 360 km per hour is equal to 40 miles per hour, please show me how to calculate using formular
360 km/hr is NOT 40 miles/hr.
1 mile is about 1.6 km
To go from km to miles, multiply by 0.62
To go from miles to km, multiply by 1.6
Kilometers per hour to Miles per hour
Feb 23, 2017 | Cars & Trucks
How do I change the mileage from kilometers to miles on my 2009 Ford Fusion?
I km = .62 miles.
10000 km = 6200 miles.
Check car manual to see if the display can indicate miles in lieu of KM's
Sep 25, 2015 | 2009 Ford Fusion SEL
How many miles to 1 kilometer?
0.6213881 miles in 1 km
80 km is about 50 miles
60 km is about 37 miles
50 km is about 30 miles
Mar 04, 2015 | Cars & Trucks
At what mileage should the timing belt be changed on a citroen berlingo
What does your owners manual say?
60,000 miles/36 km
75,000 miles/45 km
90,000 miles/54 km
Not more than 90,000 miles or
6 years
If it breaks,the valves get bent
Call a dealer or stop by & ask
May 10, 2014 | 2010 Peugeot Partner HDi
Convert miles to kilometres
1200 statute miles is about 1931.2 km. 1200 nautical miles is exactly 2222.4 km.
Feb 20, 2014 | Office Equipment & Supplies
Alfa romeo 147 flashing dasboard
This is so you can set it, just set or reset the time on the clock and it will stop flashing, same thing with the km,move from km to miles and back, if you want km then set to km but if you want miles then go to miles but you must select through it, good day.
Feb 19, 2012 | Alfa Romeo Cars & Trucks
Please can you tell me how many english miles in 2 kilometer
1.24274547 miles for 2 km.
8 km equells 5 miles so always multiply or divide accordingly i.e 40 km divide by 8 equells 25 miles (5 x 5) (5 eights into 40) just reverse for miles to Km. ok
Jan 04, 2012 | Motorcycles
Trying to find the owners manual for 2001 saturn sc2 as well as the maintenance schedule etc provided when the car was new
Scheduled Maintenance The service shown in this schedule up to 150,000 miles (250,000 km) should be performed after 150,000 miles (250,000 km) at the same intervals.
See Owner Inspections and Services for maintenance information.
Scheduled Maintenance Mileage
Maintenance Group No.
6,000 Miles (10 000 km)
18,000 Miles (30 000 km)
30,000 Miles (50 000 km)
36,000 Miles (60 000 km)
42,000 Miles (70 000 km)
50,000 Miles (83 000 km)
5
54,000 Miles (90 000 km)
60,000 Miles (100 000 km)
6
66,000 Miles (110 000 km)
72,000 Miles (120 000 km)
78,000 Miles (130 000 km)
90,000 Miles (150 000 km)
7
100,000 Miles (166 000 km)
8
102,000 Miles (170 000 km)
108,000 Miles (174 000 km)
114,000 Miles (190 000 km)
120,000 Miles (200 000 km)
6
126,000 Miles (210 000 km)
138,000 Miles (230 000 km)
150,000 Miles (250 000 km)
5
Maintenance Requirements - Group 1 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). Maintenance Requirements - Group 2 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). • Inspect the engine accessory drive belt and coolant hoses every 12 months or 18,000 miles (30,000 km), whichever occurs first. Maintenance Requirements - Group 3 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). • Replace the engine air cleaner filter every 36 months or 30,000 mile (50,000 km), whichever occurs first. An Emission Control Service . (See footnote) • Inspect the vacuum lines/hoses every 24 months or 30,000 mile (50,000 km), whichever occurs first. An Emission Control Service . (See footnote) • Replace spark plugs. An Emission Control Service.
Oct 05, 2010 | 2001 Saturn SC
My model is 360. How do I change from km go miles?
I don't think you can. But 1km = 1.61miles so times what ever distnace by 1.61.
Vote for me because I'm great :)
Jun 25, 2010 | Sportline 345 Electronic Pedometer
2002 Jeep Grand Cherokee Limited pre form service needs to be erased
Service Interval
When this feature is selected a service interval between 2,000 miles (3,200 km) and 6,000 miles (10 000 km) in 500 mile (800 km) increments may be selected. Pressing the STEP button when in this display will select distances between 2,000 miles (3,200 km) and 6,000 miles (10,000 km) in 500 mile (800 km) increments.
Reset Service Distance (Displays Only if Service Interval was Changed)
When this feature is selected the current accumulated service distance can be reset to the newly selected service interval. Pressing the STEP button when in this display will select "Yes" or "No."
Nov 02, 2008 | 2006 Jeep Grand Cherokee
Exercise & Fitness Logo
20 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Android Man
Android Man
Kenneth Simmons
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
