LG 42PC3D 42 in. Plasma Television Logo
A
Anonymous Posted on Apr 03, 2014
Red vertical line about one quarter inch thick on right side
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Jan 29, 2008
SOURCE: RED LINE GOING VERTICALLY DOWN THE SCREEN
control board
A
Anonymous
  • Posted on Jun 06, 2008
SOURCE: Red Stripe, right side
Follow-up. I found the slip on which the LG tech wrote down the part number for the board to fix the vertical red stripe. I was mistaken in my previous post. It was not the Z-Drive board. The board you want is:
X DRIVE BOARD; Part 6871QRH043A
Type in the part number in a search engine and yuo will find multiple places to purchase. Ebay may be the cheapest. That's where I got another part which got my picture back. I did not buy this part myself because now that I have my picture back, I do not want to screw it up, so I live with the red stripe.
Anonymous
  • 187 Answers
  • Posted on May 27, 2009
SOURCE: Vizio P42hd approx. 1" red line on screen, picture shifted
You will need to replace the control board and your TV will be better that a new one.
Anonymous
  • 131 Answers
  • Posted on Dec 16, 2009
SOURCE: red line down right and left side of 42" LG plasma.
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable.
Anonymous
  • 65 Answers
  • Posted on Jan 13, 2010
SOURCE: have 42PX12XC red vertical i inch lines on both
The lines on the screen show that there is a poor connection with
the flatcable on the controller board.
Ok lay your flatscreen on a table or on your desk.
First remove the backfront cover.
Then you will see the input board frame you've to remove this first.
When you removed the input board you'll see the controller board
LGE PDP 040602
MODEL: 42X2
BOARD: CTR_LVDS
PART NO: 6871QCH038A
LOC NO: 1XXX
The connections you have to check is P105 and P106.
These are the flatcable for the leftside of the screen and
for the rightside of the screen.
Try to keep the input board up to 45¤ and leave the wires connected.
Now put the power on and see for your self when you push on
the flatcable you will see the lines disapear and the screen show
normal asual.
This indicate that the soldering points are bad to resolve this you can try to resolder the soldering points or you replace a new controller board this part you can find it here.
http://flattvparts.co.uk/index.php?main_page=product_info&products_id=2592
I hope this will help you out.
I had the same problem and resolved by myself so its easy to do
and I'm sure you can do it too!
Best regards : Henk®uskita©2010.
TV dim on right side with vertical black line
The screen and the LCD are broken and are going bad and should be replaced for your TV and the ribbon might also be damaged too and needing to be replaced.
1helpful
Vertical line down the screen about 2 inches thick
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPING THIS WILL HELP TO SOLVE THE PROBLEM....
1helpful
3-4" thick vertical line on 42" sanyo plasma tv
its most likly caused by either vert controler along bottom of set or ribbon to that part of the controler if you heard a hissing sound most likly is the controler itself
Solid vertical black line on my hitachi 42"plasma towards the left quarter of screen.bout an inch an a half thick.
This will be a block defect caused either by one of the flat flexible connectors to the screen giving a poor contact or a fault within the screen itself, which result in a replacement screen required
1helpful
1helpful
Red 2 inch vertical line on right side of Vizio TV
That problem caused by a connection between LCD crystal and matrix driver,no tools yet to reconnect that metal to crystal connector,Claim warranty right away that will multiply or became larger.
Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
2answers
Thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
