Planar PL1700 FLAT PANEL  Monitor Logo
A
Anonymous Posted on Apr 03, 2014
Windows 7 driver for planar pl1700 monitor - Planar PL1700 FLAT PANEL Monitor
1 Related Answer
Anonymous
  • 44 Answers
  • Posted on Jul 30, 2010
SOURCE: on Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
2answers
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
2answers
Is there any possibility to use Planar Dome C5iGray monitors with Windows 7
Most monitors don't need special drivers. Plug it in, and Windows should be able to figure out what it needs to do.
How do I brighten the screen
Please refer the "Chapter 2" (Page No. 6) of the User Manual. Click HERE to open/download the User Manual.
Let me know if you have further problem.
Good Luck.
Thanks for using FixYa.
White scree on monitor at power up
That is not a good sign, this indicates the LCD panel display is failing, I would use until it completely goes, and replace the monitor with a new one , cheaper in the long run.
What type of adapter will I need to connect my pl 1700 monitor into my mac mini?
you'll need one of these
http://store.apple.com/uk/product/M9320G/A
mac mini dvi to vga adapter
On Planar PL1700 monitor, screen stays black after power failure
Bulb Blown
Check here on how to determine the CCFL size without taking the old one out first (best to remove the old first), WWW.LCDPARTS.NET
http://lcdparts.net/howto/selectccfl.aspx
Auto adjust
i have had the same prob with a pl1700 would like an answer also
Top Planar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
