Question about Samsung UN60EH6003 60" 1080p LED HDTV, 1920x1080, Clear Motion Rate 240, 20W Stereo Speakers
No picture, no sound, no OSD
Purchased in 12/2012, LCD panel/screen replaced 8/2013. Four months later--no picture, no sound, no OSD, backlight still working. Unit is cosmetically near mint--no scratches, dents, etc...LCD panel is intact--not cracked. Don't know why it doesn't work.
SOURCE:
  • 84 Answers
SOURCE: CRACK LCD TV SCREEN
I had one broken a few months ago. I got a couple quotes.. it was about $200 less then a brand new one. I'd just buy a new one.
For the new TV I'd pickup a screen protector for it. My son threw a toy at my TV the other day and I nearly had a heart attack from the flashbacks. Thank God I picked up one of these a few weeks earlier. It stopped it. LCD screens really break easily as you know. http://www.tv-armor.com
Mike
Posted on May 21, 2008
SOURCE: How to Fix Cracked LCD Screen?
Awesome Thanks man the links still works! - 9/8/08
Posted on Aug 09, 2008
  • 11 Answers
SOURCE: Samsung LN-S4041DX 40 in LCD TV
Hi. You can try to go into service mode and reset the LCDTV to Factory Default. This will clear out all buffer over run's and any software related issues. It may fix the problem or it may not. If this doesnt fix the problem than you need to have a qualified Technician to look at it. The problem is in the AV circuit board, a technician who is qualified to repair electronics at circuit board level should be able to repair this problem rather quickly and inexpensively. Most technicians who do not have the expertise in repairing cicuit boards to component level would rather replace the whole AV board than repair it and this will be rather expensive.So talk to the repair shop before you drop the TV off.
Be very careful when accessing service mode. I suggest to write down all information in all areas before proceeding to a factory reset. If you do not record all values correclty you run the chance of not being able to use the TV again. To go into Factory Service mode, use the original remote and in this sequence push POWER OFF-MUTE-1-8-2-Power ON, the set will turn on and enter service mode, if you hit all previous keys correctly. If it doesnt try again. When you are done hit POWER OFF and this will exit service mode and save the data.
Posted on Jan 28, 2009
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
SOURCE: Instructions to replace LCD Screen on Samsung F480 (Australian)
http://www.formymobile.co.uk/toccodisassembly.php
this is the only guide i can find :)
Posted on Sep 03, 2009
Purchased in 12/2012, LCD panel/screen replaced 8/2013. Four months later--no picture, no sound, no OSD, backlight still workingLCD panel is intact--not cracked. Don't know why it doesn't work.
No Picture/No Sound issue is either related to a power supply or main board issue. I'm willing to guess main board, it's where the video and audio signals are generated!
Apr 05, 2014 | Samsung Televison & Video
Lcd tv has sound but no picture, checked the inverter board and light is coming on the screen but no image
1. Symptom: Powers up, relay clicks, LED turns green, backlight comes on but there's no display from any input, and no OSD.
Solution: On the T-Con board labeled 320WTC2LV3.7, stickered J01420PE7F0288, check/replace:
F1 = 2A, 35V SMD (measured 9 Megaohms in circuit) - OK!
Dec 27, 2013 | JVC LT-32E488 32 in. LCD Television
Sounds from tv when titles appear
U mean the tv have pictures flashes only a few sec. than dies have the tv pragram sound left only?Yes? Mean ur tv have a tv LCD Screen Panel have no tv LCD screen backlight to produce tv pictures tv now are having backlight problems.The tv have 1 or 2 long boards that are called LCD inverter boards problems and the causes.These 1 or 2 long Lcd inverter boards only job are to produced backlight for the tv LCD screen panel to hold on to give the tv screen panel to have pictures only.Tries websites like Shopjimmy.com,EBAY.COM to those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Oct 03, 2011 | Philips Televison & Video
I have a 32" LCD
Tries tv turn off and turn on again about an hour later,see if the tv do resetting,tv might be back working to normal again.If still have the same problems.The tv have 1 or 2 long boards that call LCD inverter boards.These 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards are to help the tv LCD screen panel to have a backlight for the LCD screen panel to produced a pictures.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter board for the replacement.
May 13, 2011 | Televison & Video
I have a problem with a gift from my sister, she gave me a viewsonic n2750w that she gave up on once it started to turn on and shut off on its own, i took it to my place, turned it on, the screen turns on...
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.The board is a long in shape.
Mar 22, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
Purchased a 42-Screen "flickers"
Inverter Board going bad or loose plug, then the backlight board will fail within 3-4 weeks later. Good thing you saved a few hundred on the x-warranty, BB won't do a damned thing for you regardless; it's discontinued & they lie about their 'replacement vouchers'.
A 12" bi-metal blade is recommended for your reciprocating saw so that you can cut this thing into small enough pieces for your trash collection.
Feb 13, 2010 | Insignia 42" LCD Flat-Panel HDTV
Backlighting issues on tv set (I think). Screen goes extremely dark after about 30 min. of viewing. Does not return to orginial brightness unless unit is left off for a long period of time
Lcd tv sets are lit by small glass florescent tubes called cold cathodes and, are powered by: ballasts called inverters... these go out just like your office florescent lighting the parts can be purchased online from electronic parts houses and, are easily replaced
May 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Oct 19, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony Bravia 46 inch X2000u
I believe your backlight went out. LCD tvs have backlights that produce the picture. A hdtv technician can probably replace it.
Sep 06, 2007 | Televison & Video
Samsung UN60EH6003 60" 1080p LED HDTV, 1920x1080, Clear Motion Rate 240, 20W Stereo Speakers Logo
37 people viewed this question
Top Samsung Car Audio & Video Experts
Marvin
Marvin
Vernon Taylor
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
