When the Kingston Data Traverler Mini is plugged, it installs drivers succesfully, and a drive letter is asign to it. However whentrying to opening it it sends out the following message "Please insert a disk into Removable Disk (E);". I see the drivers working properly in the Device Manager as I plug and unplug the USB Device, and if I use the Disk Management option from the Computer Management Tool, I see the Disk there, categorized as a Removable(E:) with No Media and no content whatsoever.
SOURCE: kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
SOURCE: "Plsase insert a disk in the drive" message for USB drive
Up to you,, if you put a flash drive into your USB port, and windows see's the drive, because its listed under my computer, but when you go to open the drive it says, please insert disk
This is telling you the flash drive has failed.
The only good thing is, if you have anything on the drive, there are programs that will extract the data from the drive so you don't lose it.
You have three options,
Extract the data that is on the drive.
Try a repair program, which can erase the drive when it tries ti repair it.
Send the flash drive to the company for repair.
Testimonial: "Thank You very much sir."
SOURCE: Kingston DT100/2GB Detection and Failure
No need to worry, I will solve your problem follow this link to find how to solve it http://www.fixya.com/support/r4391734-usb_flashdisk_pen_drive_write_protect or you can see my blog, http://adhiwahyudy.blogspot.com, but this blog use indonesian languange
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
