SOURCE: Samsung LCD Monitor SyncMaster 203B
Hi this is the way how to examine
what's wrong with your LCD monitors. After you turned it on and the screen
blacked out or stopped working, you have to check that if you can see the image on the screen or
not by shining a flashlight into the screen, not directly but find the best
angle to the screen and take a look very closely. If you can see the icons or
any image, there will be a minor problem. This is because of the lamps inside
screen. Some of them were broken and it is very easy to replace. If you cannot
see anything on the screen, there'll be some problems with inverter board. If you
have soldering tool and want to fix it by yourself, check the caps first. It
may cause this problem. Some caps might show leaking or burn spot on the board
because of too high temp. If you don't have soldering tool, you better go get a
technician to do so.
Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
SOURCE: Samsung SyncMaster 204B
Got the same problem, happened yesterday for me, Did some research and it looks like its bad capacitors in the back, check out this page for more information... i'm taking mine to an electrician to fix today... luckily he's related and should be able to fix it on the cheap...
http://pavel.kirkovsky.com/blog/2009/03/samsung-syncmaster-204b-repair/
SOURCE: screen is black
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable The board can run anywhere from $50 on up. Depending on how old your monitor is and how much you've invested into it, you may find it better to just replace it with a gently used one from ebay.
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
SOURCE: My samsung syncmaster won't start. It stays black.
Hi:
You have a problem with the power supply that is built into the monitor. These are not easily repaired, as the cost exceeds the value of the monitor.
