Easily done, here is an article explaining how:
Reset Zebra printer to factory defaults
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Settings
RESTORING
FACTORY SETTINGS
initialization
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
• No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
