Blinking amber light with solid green 4 light. Dell Dimension 9100 desktop. Believe it may be a Power Supply Unit gone bad
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
There should be four lights on it. What is the code of the 4 lights?
