Does not quickstart when pushed
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
SOURCE: Precor 9.25i Treamill scrolls message "button is pressed"
Press Enter,speed up and speed down simultaneously. Then enter to view error buffer . press quick start/pacer-stop simultaneously to reset error buffer log. Hope this helps
SOURCE: The quick start button does not do anything,
You would need to replace the keypad overlay on the console.
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
SOURCE: SPEED ERROR ON PRECOR 927 TREADMILL
I had the speed error on my precor 9.23. When I opened it up I found that there are two little round magnets on the belt pulley with a sensor mounted nearby. This must be how the computer know the speed of the treadmill. I noticed that there were several little metal shavings stuck to the magnets. Not sure where they came from, hopefully not another problem. However, I removed the metal shavings from the magnets and everything worked fine again. If anyone else has the speed error it might be worth a look to see if its the same problem.
Dear Sir:
Please try with this Reset system for Code:
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
Press the "ENTER" button three times to access the treadmill's error log.
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
If you need further assistance, please reach me. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
