SOURCE: Lexmark Z640 Printer only prints to 99% and then stops
Go to start menu, open printer and faxes option. Right click your printer icon and open properties. Click on the port tab and verify that Enable bidirectional support is selected. If not click on it to check it. Click on OK and it shd work..
SOURCE: Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
SOURCE: Cannot install Lexmark productivity Centre for X4650 printer.
hardware that worked on older versions of windows will not work with win.7 i found that out with a canon multipass all in 1
SOURCE: ERROR MESSAGE AFTER INSTALLING MY LEXMARK X6650 PRINTER
Hi. That error pops up when you're using an installation cd that runs on Microsoft .Net Framework Version 2. Unfortunately, Windows 7 doesn't have that. Make sure you don't have the Lexmark installation cd in the computer. Eject the installation cd from the computer. Restart the computer and check if problem still persists. But if there's no cd in the computer and you have tried installing the software using the cd the first time, uninstall the Lexmark software by going to Start Menu > Programs > Lexmark 6600 Series folder > Tools > Uninstall. Reboot pc. Reinstall, this time, using the same installer you downloaded from the Lexmark website only. Don't use the installation cd. Hope this fixes your problem.
Testimonial: "ALMOST INSTANT RESPONSE. VERY HELPFUL ADVICE. THANKS SO MUCH."
