I can unbolt the spindle from the deck but it won't come through the hole. I tried turning the nut on the top of the pully but the entire shaft turns. suggestions?
Put your blade back on so you will have some backup on the nut. Wedge a piece of 2x4 between the blade and deck to hold the shaft while you take off the nut. You should do that before unbolting the spindle. If you are just replacing bearings, you don't have to unbolt the spindle at all. Just remove the pulley on top and the shaft with blade attached will slide out the bottom. The botton bearing, however, will be on the shaft and is difficult to get off. I use a bearing splitter to get it down far enough to drive off the shaft.
Electric impact wrench works great in these situations
but if you dont have one hold the bottom of the shaft with a pipe wrench and remove the nut with whatever you are trying to remove it with? Big 1/2 inch drive socket with breaker bar?
top nut should never be as tight as it is?
nut comes off counter clockwise
careful not to let the pipe wrench slip while you are trying to get the top nut off.
make sure your wrenches are big enough for leverage issues
you may have to do some filing to the shaft after you are done try not to put the shaft back with burrs from the wrench. could wrap the shaft with duct tape would help some
